P500 Rear wheel adjustment
Amitchellr
Amitchellr
68
281
53
Installed new wheels and tires and it looks like the rear passenger tire has positive camber vs. the rear driver. Wheel is seated against the hub and torqued to Honda spec. Is there anyway to correct it or are my eyes playing tricks. Thanks for the help.
D0FF5A8A C404 4724 A418 2C3F1502051D
Reactions: 500oneer
208,728
Looks like the spring preload is set stiffer on DS versus PS, that would do it. There is no adjustment other than spring preload that I know of?
208,728
Thank you for the help
Do you run empty most of the time? If not, put simulated weight, bed a passengers, I used 80# bags of Quickcrete in the seats, in your S X S and adjust both sides equal front and rear.
Reactions: Amitchellr
