RECALL - Power Steering Joint, 2017-2020 P700, 2016-2020 P1000 EPS Models Only
JimmyA
JimmyA
1,644
5,504
Northeast texas
Talked to the service manager this week about doing it my self, he explained it is a safety recall and is different than the run of the mill recalls. He explains to me that the inspection / repair will be documented and attached the the vin#, that means if you ever trade it in you could be on the hook for inspection / repair? If the recall ever expires? It will take 10 times longer to load, trailer, unload, load and trailer than it would take me to do the inspection / repair?
Dang, didn't know that before I posted!
Reactions: denone and Isaiah
41,933
I'm curious how I could ever be "on the hook" for something Honda screwed up?
L
Lloydtheredneck
79
407
Minnesota
i have a front shock that needs warranty, they told me about a steering check when i called they want to do all the work. im strongly against them touching my machine because i know who the service guys are. my buddy from hs is the store manager.. and i didnt buy it from them for good reason. what do you suppose if a guy was to replace the joint and throw a tack weld on it so it never moves? sure disassembly would require a little grinding but its nothing we havent done before.
P1K5Dave
P1K5Dave
2,180
8,161
Petoskey, MI
Do recalls like this have any time limit? Trying to decide whether I can wait until Spring to take it in.
Reactions: ChadD and Isaiah
M_Walker
15
32
No. Not safety recalls.
Product update campaign do expire tho.
Thanks. I was wondering the same. Mine is tucked away for the winter and I don't want to haul it to the dealer on my open trailer with tons of salt on the roads.
2019sxs
Pa
Only affects models with Power Steering
Just dropped sometime this afternoon
No info on a fix or inspection just yet. Only mentions Steering Joint B in the title.
More information coming Friday September 4th. I will post any more information pertaining when it's available.
@Hondasxs Feel free to sticky when the info becomes available
Sorry for not getting the info on here yesterday.
Thanks for the SB!
ch33br0h
ch33br0h
130
369
Jardín, Antioquia - Colombia, South America!
joining this party!
Ordered the parts, seems the joint-knuckle is on backorder till early October.
Started removing side and front fender last night.
Had easy access to the lower joint-bolt, tried to remove it and it was so tight that the head stripped.
Funny side effect is that after attempting to remove the bolt, the steering is now working normally again.
ch33br0h
ch33br0h
130
369
wow.
The amount of force to get that bolt out was intense.
Last year I purchased a set of these and today I finally got to use them REXBETI Bolt & Nut Remover
Also intense to see how stripped the inside of that joint is, but somehow the shaft that goes direct to the steering assembly looks to be in good/great shape.
now, the waiting game for the parts.
20210907 170933
20210907 170940
20210907 170946
20210907 170954
20210907 171021
20210907 171055
20210907 171332
20210907 171351
20210907 171405
TripleB
TripleB
11,890
100,846
Caryville, Tennessee
wow.
I broke 1 of mine off. Then ruined the knuckle trying to drill an extract the broken bolt. I already had 2 used knuckles from ebay on hand.
41,933
wow.
I referenced this back in post 48, but I found the recall parts # was different from the original parts number. I believe @HondaTech said this is done to keep track of warranty parts numbers?
CORRECTION: it was @toddvdh who said this might be to keep track of vendors.
The point being: go to a parts house like RMATV and look up the original number and try to find it and you might be able to get it much sooner. FYI, this part is also used on several Honda cars, so an automotive dealer may even have it.
41,933
all set!
the bolts and washers are super available with RockyMountain and have already shipped.
Had the knuckle on order with them also, and was just able to cancel it via their chat system.
thank you for taking the time to point that out -again!
No problem. It sucks having a broken machine sitting there looking at you!
livefromthetree
livefromthetree
466
1,309
Mount Vernon Indiana
Well I drug my feet all summer and didnt get this recall done and now season is here and I wont have time to leave it at the shop. Hope like hell my bad planning dont leave me stranded this fall
