GlockMeister
The Bearded Wonder
Was thinking the same lolGreat minds Glock!
Dang, I didn't think you had fallen under his evil spells also GlockiBrown noser![]()
Can you post that component list again for the Co2 tank inflators. I want to get one built. Thanks buddy,Ok, my bad. DrF! It's you!!!
Oh yeah, i've got to stay on topic so I'll share with you guys that I just purchased two of these to help with recovery.
Thanks buddy!I believe we should give credit where credit is due. Richard is the one that opened my eyes to this kit so I won't take credit for any of it's design except for adding the valve core extractor to it.
You'll need a CO2 tank. I bought one at a local paintball supply house and it was used and filled up for $20 I believe. I made a second one then I had to buy that tank new.
You'll need a hose to go from the tank to the air chuck. There are several options here. You can use a coiled hose meant for paintball or you can use a grease gun hose because they are the same threads or you can use one of these fancy air chucks with the hose made onto it. Some of the paintball coiled hoses already come with the valve you need to open and close the tank.
Then you'll need a locking chuck of your choice. There are several different styles so just choose one. You'll need to take the valve out of the air chuck so you can get more volume into the tire to pop a bead back on.
This next tool is not required but it is extremely useful. It will remove the valve core and retain it so you don't drop it in the mud and then it will allow you to re-install the valve core without losing any air.
If you choose to use a grease gun hose, here's the valve that you'll need for opening and closing the CO2 supply.
Here's a couple videos of the inflator in use and one video I made in the shop about how the valve core tool works.
These are a decent addition to the toolbox. I caught 2 of then on sale at tsc for 11.99. Me n Yankee had to use both of the kits at Winrock on the "easy bypass " on #16.
HUH?
HUH?What's me?
Did you not read he asked that question, in that post is over 3 years Old (January 2014)? Where were you then? Put on your cheaters old man do some reading of your own you salty seaman.Do you not read your own forum?@Delton and I had to use my high-lift to move a tree out of the trail because someone forgot their chainsaw. There was no turning around and we had to move it. I never dive headlong into a questionable mudhole unless I have another rig with me. I've also seen what a 5000lb winch will haul and it will haul a honda sxs up an angle that was almost impossible to walk.. again a video on your forum, (you need to watch other videos besides mudman
..LOL
Actually you need to read all the posts sir. That had been pointed out and I responded before you woke from your old man nap... Maybe it's you who have hit the proverbial old wall?Did you not read he asked that question, in that post is over 3 years Old (January 2014)? Where were you then? Put on your cheaters old man do some reading of your own you salty seaman.
I may have to start interviews for a new wingman!Dang, I didn't think you had fallen under his evil spells also Glocki![]()
I covered 4900 miles across 17 States over the past 5 days, sorry I posted 6 hrs after Joey pointed it out. I have neither the time or inclination to go through every post of alcohol infused gibberish from lunatic minds.Actually you need to read all the posts sir. That had been pointed out and I responded before you woke from your old man nap... Maybe it's you who have hit the proverbial old wall?![]()
Well then jump right in anywhere you want when you can.I covered 4900 miles across 17 States over the past 5 days, sorry I posted 6 hrs after Joey pointed it out. I have neither the time or inclination to go through every post of alcohol infused gibberish from lunatic minds.![]()
