P1000m5 Redneck radio
BigOL3
BigOL3
2,994
8,920
I bought this little Jensen radio, speakers, and antenna about a year ago, so you can tell just how critical having a radio is for me ..... lol. Now days most of my radio use is listening to conservative talk and a little golden oldies or country. I split a gal. oil jug and used it for the front part of speaker shell. After making the cutout for the speakers I used spray adhesive to attach flexible foam to shell and then added a thin piece of wood for rigidty. There was just enough room between headrest and cab to fit the speakers.
Radio had a USB connection that I ran out under front of radio, that likely will never be used. F07a9eecc3ec28a50b9dc38ad75edbf618646f33aec3fe92661bcd5933f212308444f1397c52df2b08f2c2a3e510b8ec7f9dc084ac0e9c8a9668f42cc31f2a6eD2b4fc22379b6d1a9c3e9df1173281084c8da5ed74b2bc501fb08cfac06e222dC3aa50eed3df1d1cfc076dceb272e51a456228fa7e845febd73a2cf3618e7cdbA228a6706336232efd559450ff5618cd
Sent from my SM-G965U using Tapatalk
Stauvo
Stauvo
633
910
Minnesota
Hi Bigol3,
How has this setup been working for you? I’m in same boat.
I also just want a basic system with AM/FM to listen to Talk radio but robust enough with a jack port for some 80’s tunes when with group rides.
jwfirebird
jwfirebird
927
1,446
western ny
just got these myself, was a member on here but i thought it was a cool idea, sound pretty decent and you can wirelessly play whatever is on your phone, i put a cigarette plug on it and mounted them to a plastic toolbox. i just have a bunch of music on mine for work, but if you can stream on your phone there a ton of different things you can use, pandora has a bunch of good channels
https://www.amazon.com/6-5-Inch-Bluetooth-Marine-Speakers/dp/B07D1WFK3J/?tag=sxsweb24-20
Reactions: BigOL3 and Stauvo
BigOL3
BigOL3
2,994
8,920
https://www.amazon.com/6-5-Inch-Bluetooth-Marine-Speakers/dp/B07D1WFK3J/ref=sr_1_4?crid=QP96B2JD59OZ&keywords=wireless+marine+speakers&qid=1566321332&s=electronics&sprefix=wireless+marine+,electronics,160&sr=1-4
Bluetooth does make install speakers more simple.
Stauvo
Stauvo
633
910
Minnesota
Thanks for the ideas.
Reactions: BigOL3
