Remi’s Orange Crush!
105,313
Been busy lately. Sidelined with honey doos and just plane getting $hit done! No procrastination.
Anywho, got around to doing the rear arms from @SuperATV. Ill give another shout out to them, there customer service is fantastic. One of the bushings was machined wrong. Called them and they sent a whole new “set” not one, next day.
Heres the arms. Stout and strong.
105,313
Also got the rear bandit tender and main springs on the rear shocks. Gona try them out next week! Thanks again @906UP
You can see the stock ones on the left and bandits on the right
074069A8 713C 4C05 8C78 D6FEC20DA7AE
105,313
Springs installed. Ill adjust them after a short ride. As u can see there now the same color as the stock ones. Cleaned them up, and spray painted 2 coats then 2 coats clear coat. Turned out nice,
a few small scuffs from spring install but overall look good.
Squeegee
Squeegee
JTGB in training
29,283
262,112
Springs installed. Ill adjust them after a short ride. As u can see there now the same color as the stock ones. Cleaned them up, and spray painted 2 coats then 2 coats clear coat. Turned out nice, View attachment 299445a few small scuffs from spring install but overall look good.
You’ll really enjoy those bandits, they really make a difference!
105,313
Thanks man! Im looking forward to the ride next weekend. Got to be better than the stockers! Knock your fillings out lol. The guy already had the tender springs 100% down when i got it. The stock tender springs were very small in comparison to the bandits.
Forgive me, I might have asked this from you before, where bouts you from in the mitten?
Im 30 min south of Lansing
Squeegee
Squeegee
JTGB in training
29,283
262,112
Big rapids area. What stiffness did you go with? I went with the heavy and they are awesome. I need to readjust after about 500 as the rear is just barely bottoming out on 1 setting
105,313
From what i was told there on the softer side. I did a swap for them. It was when u had to buy the tender and the main spring. @906UP knows more specifics about them. Maybe he’ll chime in.
Squeegee
Squeegee
JTGB in training
29,283
262,112
Are they the ones he was running? They’re a bit softer springs. I’m contemplating sending shocks in this winter. Gotta figure out what I want worse, bigger tires or new valving on shocks.
105,313
Yes, i believe they were. Ill run these for a bit and then send them off eventually. When I drove @Tramguage1 machine for a long ride, his was very nice. He had sent his off as well.
5,024
22,434
You can do tires any time, my R is going in to Weller Racing for springs and valving as soon as I get to Arizona, probably next month.
906UP
906UP
13,006
121,240
da Yoop
@Squeegee knows what springs I had, they worked great until I added the rear bed extender/spare carrier/tailgate thing so I switched out the rears for the heavy spring rate.
105,313
Thats right. It was the added weight that made you change them.
105,313
Got some shock covers. The idea is not new at all but when i seen a set on @Tramguage1 Talon and thought🤔 brilliant! Good way to keep the mud out of your shocks to adjust on the fly if you want. So i found these and there orange to match the machine!
Im weird!!!!😂
105,313
As some have seen im selling my P1K5’s CEC enclosure cuz i chopped my top. There a great product and the guy is great to deal with @joeymt33 can agree with that. I like his doors so much that I got a set for the talon. Will be nice on those cool mornings or days like this weekend at the cabin. Were doing a color ride! The trees will be 100% in our area from what im hearing and 50-55 for the high. The boss will enjoy a majority of the wind staying outside the machine.
install was quick easy and seals great.
E85CB6D5 1D2F 45C8 8C68 E630CED2C79D
F6180E1A 052F 4641 8EC9 5E39E42DE62B
105,313
Also got my tusk rear cargo bar on. This one gave me much more room for the pack outs to be put in and taken out. Prob gona find another place for those trail permits tho.
906UP
906UP
13,006
121,240
da Yoop
Im weird!!!!😂
View attachment 300518View attachment 300519
I ordered a set after I saw Tram's at TO.....in blue of course because it's the fastest color 🤣
What's the shocks in place of the swaybar links? 🤔
