P1000m5 Remi’s Stroker 30 Build And Other Cool Bs!
115,943
Looking good there feller did you have to add some on the front section of the cage I had to add I think 1-3/4" to mine to get it
to line up with out forcing it to get the bolts back in I never done the rear it was taken off when new and never went back on I posted several pics when I done mine
Thanks
Yes, added 1-1/2” to the center front . Was just enough to get the right pitch.
115,943
Im painting her up now. Have to rotate the middle clamps and a few other adjustments to the roof to make and the upper windshield.
Reactions: pct and Lady01
115,943
Heres that spacer
115,943
Mines about to get cut down next week. Do you have any close up pics of the grab rail on passenger side. I think going down 4" on mine but looks like might be into that grab rail section. Curious how yours came out.
This is about as close as i get u a pic at the moment. The SATV flip lower half windshield will fit. I cut 4-1/2” off the cage all the way around. Id cut the dam handle off but my tiny little wife like to have it so it stays.
827AB7E8 36BA 49BC 8950 91FFA1664799
115,943
Up at the cabin this weekend and got a chance to get the P1 out after the cage chop. We cut and split and stacked 5 cords of wood. Best time to do that up here when the snow is mostly gone, no foliage and cooler temps. Machine hauled all the wood we cut and the cage chop was nice to drive with. Just need to put the top on and the rest if the windshield and should be good.
9D25E7D8 5A1A 40D7 84B5 D92ABE864584 B0F6478C 7FF8 4B27 A472 365EEA578D87
L
LarryAmboy
906
2,019
Castalian Springs, Tennessee
View attachment 260476 View attachment 260477
Gotta be careful you don’t freeze the nipples
Reactions: Remington
115,943
We got all the wood stacked in the lean too and all the scraps burned. The pioneer was great hauling the large logs. Good times with some buddys, fireball and beer!
C57F0A7D 62D6 489B 86FC D12CD9786480
115,943
Got back home this evening and decided, what the hell... im gona put my hard top on.
had to make a few adjustments that @joeymt33 told me i would have to make to the middle bracket and the rear in order to fit cuz my chop is exactly the same as his. Basically extending the rear bracket and removing the middle bracket and moving it about 1/2 further back and having to drill a few holes for it to fit. The end result was BA! Fits great and its ready to rock! Now for some other quirks not related to the chop top to get done.
92BC317E 594C 4135 B1CE 8307782007D7 8CDD2787 049A 48A2 A1E5 8591560861D1
View attachment 260687 View attachment 260688
That looks so much better.
How’s the handling? Can you notice a lower CG?
115,943
Yes it does look chit tons better!
The handling is a lot better, not so topsy terby feeling and more rigid. Now i just need to add some bars from the brush guard to the A pillar. 😎
62,250
Looks great! I need to do mine
115,943
So some spring cleaning lol.
had an Auxbeam 12” LED bar that finally after 4 years of muck started taking water. So i had a credit with lifetime LED and got this 12” bar. Had to re locate it to the top cuz the brackets would not allow me to put it low like the other one. So far the bugger is bright. Will see how it holds up in the muck
Image Image Image
115,943
Another spring cleaning project ive been working on is my dual battery situation. My Odyssey 2nd batt expanded but did not explode. So i needed a way to rectify this situation. Answer, a small float charger/tender to mount under the hood to take care of both batteries while on dry doc. Then I still needed something to stop the battery from being damaged if i leave an accessory on for a period of time when drinking 😁 or just Rockin out 🤟. I got with my good friend @joeymt33 and he gave me an idea that he uses. A Blue Sea m-LVD low voltage disconnect. You set it up in series with your secondary battery and whatever accessory's you have hooked up to my case a large braker and the voltage not to drop below as in my case i set it for 11.1vdc and it will shut the system down so u dont drop to the dreaded 10vdc or below witch is starting certain death to a battery.
Pics are of the charger.
Image Image
115,943
Now the Blue Seas was fun! Lol
Kinda F’d up Wiring diag so the override switch took a bit to finger out! Haha. Heres the set up...
Image Image
Similar threads
Replies
Views
382
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
