P1000m5 Remi’s Stroker 30 Build And Other Cool Bs!
115,929
And finally...running out of room fast for switches. Found this dandy spot for the override switch that comes with the Blue Sea’s. Again, the override switch is to do just that, override the cut off if u need too.
Image Image
115,929
So I finished my hook up for my battery charger. Got this 110 power plug from NOCO and drilled it to fit on my front cowling. Now i wont have to remove the hood to plug it in for charging. Looks like a diesel! Lol. Thats what im gona say when someone ask! “Yeah its for my block heater! Got a big block diesel crate motor in there” :rolleyes: 🤣
TripleB
TripleB
18,321
163,726
Caryville, Tennessee
View attachment 263657View attachment 263656So I finished my hook up for my battery charger. Got this 110 power plug from NOCO and drilled it to fit on my front cowling. Now i wont have to remove the hood to plug it in for charging. Looks like a diesel! Lol. Thats what im gona say when someone ask! “Yeah its for my block heater! Got a big block diesel crate motor in there” :rolleyes: 🤣
Fancy
115,929
Them look good. I havent used those yet. My 169.00 Allballs are still hanging in there
I still have allballs in the front. And there still good. Just had an issue with a boot clamp. Was going to get those for the rears but decided to go big and hope for longevity
Isaiah
Isaiah
2,191
6,964
Altamont TN
I hope the 2.0 last longer than my 1.0 that I had in the rear! Lasted about 4 months!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I hear ya. I couldn't keep my factory boots from leaking. After replacing boots on both sides I decided to just replace whole axle.
115,929
Well, finally got around to installing my badly needed rear axles. The stockers are still good. The passenger has a click and will b good for an emergency. The driver side was fine but a bad band on it. Like the 4th one ive had on there. Heres the new bad boys on.
Image Image
115,929
Howdy folks! Been little over a month since ive been on. Been busy as you would guess. So i added some Milwaukee pack out boxes. One is a cooler, small tool box and a large one and some small boxes that i might change out later, will see. Kinda got sick of my storage bins and separate cooler to have to tie down. The inly sacrifice is the bed liner. Not a huge sacrifice cuz it was a PITA to remove at times. So ill just get a heavy rubber mat to lay down in the back when im hunting. Otherwise, im still able to use the back seats cuz the pack out bases are close to the same size at the seats. Cant take credit for this. Some of my other friends @Russ989 and @joeymt33 to name a few initially came up with the idea and i just put my own spin on it lol.
115,929
I thought so. I've got Rigid boxes, there ok and water proof, but seem to be a hassle to unstack.
So far these seem to be easy to unstack. The teeth and connectors are huge so that should help.
Reactions: BWAF and Smitty335
Similar threads
Replies
Views
379
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
