i recently replaced the clutches due to them being burnt, and the unit still slips between shifts at partial throttle, wot shifts fine.
its a 2016, sxs1000m5dg, ive done the clutch relearn several times and it does not have the updated clutch cover. it took about 20 tries to get the clutch relearn to actually take, with the oil warmed up, i followed the procedure in the manual over and over until it was stuck in my dreams.
my question is, will the updated clutch cover fix the slipping?
i removed and cleaned everything, getting all clutch/burnt deposits out, cleaned the solenoids/valve body. did a full service on the machine, spark plugs, air filter, pre filter, oil and both filters as well as the front trans under the seat.
when the machine is cold, it shifts a lot better between gears only a few hundred rpms between shifts, as it warms up, it climbs a couple thousand rpm between shift. so if im at 2k and it goes to shift, it goes to 4-5k before it shifts.
when i put the new clutches on, i noticed one clutch pack sits closer to the center gear than the other clutch pack and didn't pay attention to how it went when removing. but when i installed the new clutches, the gears seemed to line up perfectly and the cover when on smooth by hand like nothing was in a bind, but the back of my mind is wondering if i put it on backwards?
im at a loss as to why it slips so much between shifts, weather its in at or mt, dosn't matter on the slippage but im not driving it much because I don't want to damage the new clutches. I did soak them for 24hrs before installing them like we do on motorcycles.
sorry for the lengthy post, ive ordered the upated clutch cover and will put it on when it arrives but i don't think thats going to fix the slipping, just keep the front clutch cooler to last longer.
thanks
thanks
