P700m4 Replacing tires question
Colton
Saint Maries
So it's not a secret the factory tires suck... bad.... I found this out the hard way 9 miles from
The truck last night. A stick stabbed right through the tred of the tire. We made it back to the truck with out damaging the wheel I don't think.... anyways looking at replacements.
If I replace the rear two with a factory size (25x10-12) looking at the bear claws will I be okay leaving the two front stock? I can afford to buy two rears right now just can't afford all 4.
The machine has 300 miles on it and tires have no wear on them.
Thanks
Colton
Reactions: sharp
swsebek
swsebek
2,854
5,828
pa
Should be fine. What about fixing the tire. Threw the tread is usually fix able
Reactions: Tflynn and sharp
swsebek
swsebek
2,854
5,828
pa
That way you can save to buy 4 larger better tires.... 25 inch tires are ridiculous for this machine,,, 27 inch is perfect IMHO
Colton
Saint Maries
654317376f6ac62303e2cc1a71cec64c
I don't think it's fixable plus the amount we did have to drive on it while it was flat I'm assuming it's garbage
Reactions: swsebek and sharp
swsebek
swsebek
2,854
5,828
pa
I bet that's fixable and wouldn't be afraid of it on the 700. Doesn't turn em fast enough to do anything. Take that tire to a fix it shop.. if 4 large plugs don't work then grind in side and glue patch in it....I
allgm1
allgm1
1,049
1,484
New Hampshire
I put a patch on the inside and a tube on one of my stock front tires after jamming a stick through the side wall, put 1300 miles on them like that with no other issuses.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I would be hesitant to only replace the rear tires unless you replaced them with stock tires which I doubt you want to do. The reason is, not all 25" tires will actually measure a true 25". This is true for all sizes by the way. Brand "X" 25" tire might actually measure 25.25" while brand "Y" 25" tires actually measure 24.75". Even a slight difference like that can goof things up when you engage 4wd.
Reactions: joeymt33
jawquin
jawquin
299
652
Indiana
Thanks
Colton
I think you'll be fine if you replace them if ya can't patch it. I am a bit backwards but I ran stocker's and wore the front ones out in 2400 miles. Threw a set of stock size mud lites on front and wore them out with the stock Blackstone rears still on. Blackstone rears still have some thread and took em all off at 4885 and threw same size 27x9 radials all 4 corners and love em. Depends on your riding. I don't think I'd mix bias and radials but no fear in tire brand changes same size in pairs front or rear. I even ran some Bear Claws on the front for a short period with the Blackstone's on the rear. Good luck.
20161203 113328
N
NHPioneer
17
41
New Hampshire
Ok folks. Here’s my question from a newbie too. P700-4 w/1000 miles on the stock 25” tires and the rear tires are getting worn. I probably should replace them with New all around and everyone recommends 27”. I love the deluxe stock rims. I do really no muddling in NH as it’s just a few puddles. The trails are mostly hard pack logging roads (dirt) and some stoney boney trails and then toss in some tar access roads 10% for good measure. I was looking at 27-9-12s for the front and 27-11-12s for the rear. Or do you recommend one size all around and if so what tires for either option? Thanks. Like I said, I’m a newbie so don’t beat me up too bad.
swsebek
swsebek
2,854
5,828
pa
For what you say,I would say tusk terrabites 8ply 27-10-12 all the way around...That way you can rotate
Reactions: Tflynn
Max718
Max718
246
366
Mississippi
I'm confused..if he runs the same size all the way around .. all 4 tires on deluxe rims.. why could you not rotate them ?
The rear rims are wider and will rup on the brake calipers . When I took the stock wheels off mine I tried to see if the rear would work on the front and seen it wouldn't
Reactions: Deluxe700
Deluxe700
Deluxe700
856
1,101
Central Arkansas
OHHHH...didn't think about that.....yep that makes sense
N
NHPioneer
17
41
New Hampshire
I checked online and could not even find tusk terabytes in 27x10x12 with or without rims.
swsebek
swsebek
2,854
5,828
pa
I did too. They got 9s and 11s but no 10so_O
I only recommend them cause of the good reviews I have heard on them for your ride. You could just do a 9 on front 11 on rear and call it a day.
