REV PROBLEM 5000RPM
Shako1921
tbilsii
hello
recently i have purchased used Talon 1000R , it starts well , but it doesnt go up than 5000RPM approximately ( it makes like red line ) , i have tried every gear , 4x4, 2x4, everthing , but still nothing , has anyone had same issue before ?
F
Fyathyrio
245
675
Air filter clean? Oil level too high?
Shako1921
tbilsii
Air filter is new, i just changed oil and everything is good with level
Hometeam
Hometeam
976
4,009
Normal, IL
My first thought was the seatbelt safety but I am not sure you can change gears without the seatbelt locked….just throwing out ideas.
Shako1921
tbilsii
there is no check light or any light on dash , i dont know what to do , i amnt in USA and unable to contact dealer , everyone's opinion is important
Reactions: Backwoods
906UP
906UP
14,243
134,964
da Yoop
Put new spark plugs & fresh fuel in it then let us know, it's often the simple things
F
Fyathyrio
245
675
Does it struggle to reach 5k (if so, recommend a compression test) or does it hit 5K fairly easy then act up like hitting rev limiter? (computer or other elec issue maybe)
Video with audio could be helpful, if possible.
