P500 Reverse cable adjustment
178,792
I adjusted my reverse cable tonight in about 2-3 minutes so I would not have to pull it to go in reverse. Works great!
That was one of the first things I did to mine. I noticed @PistonHonda was still using his in one of his videos. That was a pita when plowing.
Little_g
Little_g
404
660
Parker, AZ
Would it even go into reverse while you were moving forward? I've been wanting to do this myself but like @HUCK said I don't trust myself.
Reactions: Dp5hunter
Mudder
Mudder
NTC Ambassador of Walls
11,656
88,020
Mine jerked the transmission when I was barely rolling forward and hit reverse. My bad.
Reactions: Little_g
178,792
Yes, it will. I sometimes get a little impatient when plowing and shift into reverse while still rolling forward slightly, it'll give you a good jerk.
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
Where is the adjustment point located in the hood. I am going to adjust mine.
Deleted member 3748
I searched the site and can't find it but if I remember correctly, it's easy to figure out. My power at the house is out today so I'll go out and adjust mine and let you know what I find.
Deleted member 3748
Thanks as soon as you do let me know ;) so I can do mine.:)
The first thing I did was take it apart to see how it worked.
WP 20170707 13 35 58 Pro
I recommend you don't do this because it was a pain in the ass to get it back together.
My cable had the nuts adjusted almost all the way back as far as they could go (away from the lever). This allowed normal lever operation. If I turned the nuts toward the reverse lever, the lever eventually stopped working and it would shift into reverse without pulling the lever. Adjust it for your preference. :)
WP 20170707 14 26 15 Pro 1
Dp5hunter
Dp5hunter
3,056
Good so it's in the hood right by the firewall.
178,792
Good thread @William . I did mine so long ago I had forgotten about it until I saw Piston use his. Fast, free and easy mod.
