P500 Reverse cable adjustment
William
William
1,442
2,887
Flowood MS
I didn't mean to type that first part. It was actually going to be a longer walk through how to but I noticed someone else did already. Kinda sounds smartassy... lol
Deleted member 3748
That's good. I thought I may have to go all 1980s on you! :D
Honda
11,322
84,135
Updating an old post for visibility to newer members. Reverse Lever Adjustment mod is a good one to consider. Also the seat belt/speed limiter disable trick for those frequent exits doing chores around the property. Both so simple to do. Thanks to whoever shared those original posts.
WillyBill
WillyBill
Wheeling Addict
473
1,887
Clinton, Utah
  1. Talon X LV
Updating an old post for visibility to newer members. Lever Adjustment mod is a good one to consider. Also the seat belt/speed limiter disable trick for those frequent exits doing chores around the property. Both so simple to do. Thanks to whoever shared those original posts.
Is that why mine governs out at 39 MPH? I never wear the belt (Well almost never-but don't tell my wife. LOL )
Reactions: Dp5hunter
Danno13154
5
Oklahoma
Good thread @William . I did mine so long ago I had forgotten about it until I saw Piston use his. Fast, free and easy mod.
That was one of the first things I did to mine. I noticed @PistonHonda was still using his in one of his videos. That was a pita when plowing.
would this void the manufacturer warranty? If so, I’m gonna have to wait a bit.
156,867
It's so easy to do that you could tighten it back up before any service. I was just thinking about this the other night when I was plowing. Also made me think about how they should've put both paddle shifters on the left side again, one hand operation. ;)
Reactions: MSmillie and Mudder
11,322
84,135
Yep, just turn the nut back if you have issues. Good improvement, wish I knew it from day one. Need to find a label that says Dragster Shute Release...for that P500 8 second 1/4 mile run!
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
Man that's some wishful thinking bot man that would be so bad ass.;)
