P1000 Reverse light installation
I bought THIS LIGHT because it was the closest thing I could find to your QuadBoss.
And I bought this WATERPROOF Electrical Quick Connect because because you and @JTW was all giddy about quick connecting the light... I dunno.
Lmao.. I'm a fan of the quick connects because we're using cheap lights.. it's likely they'll get water in them or broken at some point, so it's just waaay easier to put them on a quick connect now and replace them by plugging the new one in. All of which can be wired, crimped and whatever else done on the work bench, rather than an awkward spot on the sxs.
Jshell3
Big Props to @ToddACimer for answering the call tonight.
I was struggling trying to locate
THIS PLUG.
As simple as it was to get to, it was múy hidden...
But once I found it... I was off to the races!
Reactions: JTW and ToddACimer
Jshell3
Done!
Works like a champ!
Key on. Reverse. Every time.
IMG 4695
IMG 4696
IMG 4698
IMG 4699
1BadDart
1BadDart
1,448
13,430
W. KY
Jshell3 what lights are you using?
Tramguage1
Tramguage1
Texan
7,519
30,905
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
@jshell3 sold his.
Then he decided to use this free upgrade. We still speak now and then. Free Upgrade!
Same here I text back and forth every once in a while. Great guy!
Reactions: JsheII3
Skin0375
Skin0375
42
59
West Virginia
I hooked up a quad boss 3.5" flood light to my reverse switched power on my 1000-5. The light is mounted in the center of the body under the tailgate. I used a nutsert and single bolt of mounting the light. For anybody looking to do this it's easy with the reverse light harness from the p700. The harness is 08Z02-HL3-A00 from Honda. It hooks up to the green connector under the rear passenger floor on the backside of the engine. As wired the light comes on whenever the Pioneer is in reverse and the key is on.
Does this light supply enough flood too shine out on each side of the rear tires well, and how far back does it flood?
ToddACimer
ToddACimer
Pioneer 1005-2
3,736
15,794
Oshkosh, Wi
I switched to 2 lights a couple months later and 2 is definitely better. I can see behind the tires in both mirrors.
Reactions: Skin0375
ToddACimer
ToddACimer
Pioneer 1005-2
3,736
15,794
Oshkosh, Wi
Finished up my switched ground for reverse lights in reverse and with the dash switch. I found that using chassis ground through the switch and to the lights caused a back feed to the transmission ground signal which kicked the transmission out of gear. To eliminate the backfeed, I added a diode before my dash mounted switched ground. I found a mini fuse sized diode AC Delco 96500202 which is a GM fog light diode and it fits in a little fuse mini fuse holder Littlefuse p/n 0fhm0001xp. This allows the machine to provide ground through the diode but does not allow ground back from the lights and switch when the dash switch is on. Double check the mounting orientation such that it is blocking ground the correct direction. The marking on the diode looks like a vertical line with an arrow pointing towards the line. The arrow should point away from the lights and added ground
Here's a picture of my test harness. Light connections and added ground on the right, diode center and plug to vehicle left.
Img 20181125 125127 jpg
Updated switch panel
Img 20181125 132756 jpg
OnTheJob
OnTheJob
426
925
Bristol, NY
This is wired to the reverse gear. Really bright. Clears the bumper too.
IMG 58021
IMG 58061
IMG 58081
Liking that switch plate too!!! :cool:
