P500 Reversing rear rims/tires ? Tell me how stupid this really is, please...
SouthParkColorado
SouthParkColorado
152
651
Hartsel, CO & Aurora, CO
www.flickr.com
  2. Other Brand
So on a whim I reversed the tires on the rear of my 500. There are times I know I won't be doing 50" trails and I may be on sidehill trails ... Doing this swap I go from 50" to a stable 58" with 10 minutes of work. Driving it for a couple miles didn't feel weird in any way I could actually notice. So if someone can give me all the reasons this is nuts at anytime, anywhere, I'd appreciate it. And if anyone has seen a reversible rim for sale that does what I wish it could, I'd really like that! Thanks.
IMG 20190507 104721
IMG 20190507 104636
IMG 20190507 104649
43,293
View attachment 131753 View attachment 131751 View attachment 131752
Isn't there a taper on the lug nut holes on one side? That's usually what centers the wheel. Check your studs/wheels often If you do this, cause I think it will chew them up eventually.
NitroxDiver
NitroxDiver
488
918
Concord NC
No taper on the back for the lug nuts to tighten against and the shape of the rim will not have the same contact area as the correct side. I think you will have problems keeping the wheels tight and you may damage the lug nuts or studs.
SouthParkColorado
SouthParkColorado
152
651
www.flickr.com
  2. Other Brand
Go here, look at the pictures.
Then turn the wheels back around the right way.
P500 - Offset Question
I saw that post before and decided my P500 wasn't a trailer. And P500 rims aren't built like low cost trailer rims..
IMG 20190507 104704a
IMG 20190507 104649a
IMG 20190507 104636a
And what happened to that fellow at highway speed is a poor example of anything, except drinking and driving. Consider me double warned..
Eltobgi
Eltobgi
4,599
15,186
North Dakota
How many miles have you ran it this way so faro_O
Also, how about a few pics showing the side and front looking back on the reversed rims.
Thanks
Reactions: Gassygordo
P
PBishop
41
135
Nova Scotia
If this is an option and causes no issues, you can pick up a cone shaped grinding wheel at most hardware stores. This will put your cone shape hole for you luge nut. The old VW bugs ran like this forever when I was younger.
