P1000m5 Rock Donkey v2 Long Travel
There's a bar right under, front to rear of your battery. I used 2 long J bolts/stock battery hold down/ to bolt the battery down in that spot. Die grinded a clearance slot in the skid plate to put the J bolts in.
Good to know I'll take a look at it. Want to get the electrical finished up tomorrow night and maybe have everything buttoned up by Monday night so I can start breaking it in.
Reactions: JTW
Too nice a day and my 2yo daughter was screaming "Go go go go go go go go go...." non-stop
The Mistress needs to be broken in anyway.
F2728d1e990b195de66f78985ce40831
ghost
ghost
993
1,873
BC
Looking good!
I wish you did your build last year so I could borrow a couple ideas.
Your switch panel is very similar to mine. Did you custom order that wiper/washer rocker? I didn't see where it was possible to do that on the order form.
Reactions: ohanacreek
Looking good!
Ha sorry/thanks, I've copied other people's ideas, changed s few up added a couple of mine.
OTRATTW lets you customize rockers. You chose a rocker the can customize text.
Bcfa88164da2e81bb7fe8497f5129ca4
I got a OFF/ON/(ON) DPDT Switch ON turns just the wiper on, (ON) which denotes momentary, turns on the wiper and washer pump.
Had one on my 700 it was GREAT.
Be0690134c9f52b1a5962c21ec339108
Eece7a9c480d9a0d7d04d2b99bcd18b4
ghost
ghost
993
1,873
BC
Thanks - I've got the same switch but your rocker has "Washer" on top "Wiper" in the middle and emblem on the bottom. If you just ask for Washer / Wiper they would be spaced out like that. I think....
I'm in the process of adding a single momentary switch - "Mist".
Just tell them
(bottom) logo
(Middle) Wiper
(Top) Washer
That's how I ordered mine.
I've got two charging ports, and another voltmeter I'm adding when @mystic1219 has another run going. I waited too long to order the plate so I bought what he had, I'm ordering another one with 14 slots which will give me one spare slot. Just in case.
Reactions: sharp and ghost
Boomboom907
596
620
Washington
Do you actually have heated seats? How did you do that
Sent from my Pixel XL using Tapatalk
So does that mean with the switch off you have heated seats? And when you turn the switch on it's blowing the heat away?
I can flip the switch so when it's in the "down position (off) the fan is on and my seat heat is (off)
I spent $35 on this cooling solution if it doesn't work I'm going to block the trail and insist on going to my safe space!!!!
Been working on the wiring, it's fun to see all the bits and pieces go on, but this has been the tedious part, I've been connecting and running wire since noon.
It's all under the hood now I've gotta land it on the switches.
Maybe I'll be done in time to take the Mistress for a midnight ride.
PDM60
"TRUE" battery isolator
Jumper Cables ( used them because a 100' roll of 4ga in black and in red was $200 and they were joined together)
I wrapped the cables in 1" Wire loom to protect them.
300amp Circuit breaker
E209f1e299fd887538df4194e791bb00
0562cb5d9b246a7a72290e804dc06a6a
B34021adaa982804c07eccc585f0cea3
B3c0bd229208ba31e8043ba5d9449458
Boomboom907
596
620
Washington
Wait. Did you paint or plastidip your rig?
Yup.. I couldn't do it all at once and I had to have week long intermissions to keep from breaking s***!!
Reactions: GlockMeister
Well I can't get the skids on till I finish the wiring.
Optima is under the seat and the bilge and reverse trigger wire are fed under the floor.
Last part is getting that fed under and the skid on.
14f8941a2f9b393397eacafc4b700f86
Reactions: sharp and JTW
Similar threads
