There's a bar right under, front to rear of your battery. I used 2 long J bolts/stock battery hold down/ to bolt the battery down in that spot. Die grinded a clearance slot in the skid plate to put the J bolts in.
Looking good!
I wish you did your build last year so I could borrow a couple ideas.
Your switch panel is very similar to mine. Did you custom order that wiper/washer rocker? I didn't see where it was possible to do that on the order form.
Thanks - I've got the same switch but your rocker has "Washer" on top "Wiper" in the middle and emblem on the bottom. If you just ask for Washer / Wiper they would be spaced out like that. I think....Ha sorry/thanks, I've copied other people's ideas, changed s few up added a couple of mine.
OTRATTW lets you customize rockers. You chose a rocker the can customize text.
I got a OFF/ON/(ON) DPDT Switch ON turns just the wiper on, (ON) which denotes momentary, turns on the wiper and washer pump.
Had one on my 700 it was GREAT.
I'm in the process of adding a single momentary switch - "Mist".
Do you actually have heated seats? How did you do that
Sent from my Pixel XL using Tapatalk
Ha that's my Bilge Fan switch. I wondered who'd be the first to ask.
So does that mean with the switch off you have heated seats? And when you turn the switch on it's blowing the heat away?
You get 10 points for that comment!I can flip the switch so when it's in the "down position (off) the fan is on and my seat heat is (off)
I spent $35 on this cooling solution if it doesn't work I'm going to block the trail and insist on going to my safe space!!!!
Wait. Did you paint or plastidip your rig?
Yup.. I couldn't do it all at once and I had to have week long intermissions to keep from breaking s***!!
Lol - I almost changed the label on mine to "Air Conditioning" but figured I confuse myself so left it as Engine Fan.Ha that's my Bilge Fan switch. I wondered who'd be the first to ask.
I have heated seats - use them frequently on early morning hunts or just bloody cold in winter.Do you actually have heated seats? How did you do that
