Rocker Switch Mounting or Auxbeam
WildMounts
WildMounts
54
289
  2. Talon X4 LV
Looking for a way to mount rocker switches or an auxbeam on the lower intercom slot of the rugged radio dual dash mount for a 2020 talon. really want someone flush mounted, but open to options.
105,305
This has been covered a few times. Try the google search for further reading.
I have the Auxbeam for its simplicity.
Reactions: Smittyp
Mopower58
Mopower58
CST is the Best!
70,034
643,502
Crystal Springs,Ms.
Try contacting Crossroads3D.
Reactions: Smittyp
WildMounts
WildMounts
54
289
  2. Talon X4 LV
I know its been covered a good bit just can't find if there is anything that will run in the space under the radio mount, its where the intercom slot is on the mount. I would like to keep the mount and fill it in with something useful.
Reactions: Remington
105,305
Do you happen to have a pic of the area you want it to be at? I’m guessing two different areas where you’re saying you have a radio mount. When I get home later, I can show you where I have my switch panel mounted.
Reactions: Smittyp
WildMounts
WildMounts
54
289
  2. Talon X4 LV
First picture the what I have, looking to cover the opening. Second shows the intercom installed.
4C13CA8B 1D4B 4972 ACCF 7AC15C37EBEA F338364E A910 46F9 9C8B E8DAFE39D4E6
ScottJ24
32
Cresson, TX
Rugged Radios has a block off plate for the intercom slot on their mount. I believe if you call them they may have one for switches thats not on their website.
105,305
Welcome, Assuming u have a Talon, 2 posts since 20’ and no Intro
u Got any Pics of your rig?
could always start an into with the pics.
105,305
View attachment 380126 View attachment 380127
So mine is where your rugged radio is located. Then I have a switch plate up above where My gauge was located. You can do the same. Ill get the name of the guy that sells them for you. That will give plenty of space to Mount it.
Reactions: Smittyp
