Tflynn
Not a liberal
I threw some roll bar clamps together this week. I used a lathe and a mill, BUT you could use a drill press with an end mill bit and get similar results if you took your time. These can be bought for $30+ each from superatv. For me that was a bit steep, since I wanted four of them. Material cost is about $12 each. I used 2.75" OD tube with .5" wall, giving the desired 1.75" ID.
I used the mill to split the tube in half. But if you don't have a mill, you could use a cutoff wheel and grinder and do pretty well I think.
Just an idea I wanted to share with everybody. Now, on to step two of my latest idea...
