P500 Ron's "Huntin Buggy"
Heloron
116
290
Oroville, California
Just finished up getting her ready to go, 3500 lb Super Winch, Walker Evans font shocks, 1 1/2" spacers front and rear, Rip Saw R/T 25" tires on stick rims, radiator screen, single rifle floor mounted gun holder, Chooglin Glove box, Luxen quick release back window, 15" front half window hard face luxen, fold over from the roof front windshield (lays on roof top when not in use), Sojoy seat heating pads for bottom and back seat, beefed up skid plate using 1/2 " Kydex sheeting, 3/4" plywood cargo rack base with storage container, two rotomax gas containers and a Kolpin hard case gun holder, and more to go when time and funds become available.
IMG 0801 IMG 0814 IMG 0826 IMG 0822
11,304
83,913
Seat heating pads in a P500! Interesting. Getting cooler and time to remove the heat mat for that mid seat engine heat.
155,576
Bought one for mine last year for plowing, never did use it though. Aside from what comes up between the seats I figured it was the cheapest easiest way to go.
11,304
83,913
Looks like that collectors item green! Nice outfit!
Heloron
116
290
Where and how did you affix the gun holder? Images?
Al
If you are referring to the single gun mount inside the cab, I used two pieces of 3/4 " strapping, about 1 1/2 " long, drilled out a center hole and tapped the hole to to match the threads on the gun mount. I put one on the outside and one inside with two small screws and nuts holding them in place on the dash.
IMG 0807 IMG 0808
Heloron
116
290
Don't know how they'll really work, but I'll have a pretty good report on them by this time next month. The Sojoy heating pads were $73.00 and I paid $20.00 to have the pads installed. I ran the wiring and installed the switches, one for the driver and one for the passenger, has 3 positions, Off-Low-High. At 71 yrs old, I like heat on my bottom and back when it's cold. You get wimpy with age.
Reactions: Miss_Oak
AlR
AlR
470
1,166
Nanaimo, British Columbia
If you are referring to the single gun mount inside the cab, I used two pieces of 3/4 " strapping, about 1 1/2 " long, drilled out a center hole and ...
That's awesome. I was also wondering if you attached a Kolpin gun scabbard somewhere? If so, how did you affix?
Screenshot 20171017 205044
Heloron
116
290
I added the Kolpin gun case for hunting in Colorado, has be carried in a enclosed gun case. I mounted it to the 3/4" plywood Base I made that is attached to the back frame rack which is held in place using zip ties. Can have the whole thing off as one unit in a matter of seconds.
IMG 0822 IMG 0830
