P500 Roof vent.
Rpoore
6
Seneca, s.c.
Just got a horse trailer vent to mount on pioneer 500 roof. Its will open to front or back. Hope it helps with air flow. I will let you know how it works out. Link is trailpals hourse trailer vent.😁
irishnproud
irishnproud
12
41
Rockford, MI
@Rpoore how did this work out? I was looking at the same vents for air flow purposes.
Reactions: Mudder
Keebler
Keebler
264
891
St Charles, Mo
I have a windshield an no back window and have heard that that causes max dust in the cab. Sounds like a rear window would help with dust and roof vent might keep get good airflow in the summer. Thoughts?
208,730
My favorite set up for Summer is an Alien Shade roof, shortie windshield and nothing else, unless it's raining.
irishnproud
irishnproud
12
41
Rockford, MI
My brother had a gator with roof and windshield and the dirt swirled into the cab really bad. When I purchased my 1000-5 LE the salesman suggested that if I get the windshield/roof that I should also get the back panel because it would knock down most of that swirl. I followed his advice and purchased the Honda roof/windshield/back panel and the air flow is not great so it gets hot in the summer but it does keep most of the dirt out even riding in a very dusty environment. I'm just hoping to find a way to get more air flow to cool it down when it's hot out.
The Green Goat
The Green Goat
2,255
16,663
Ohio
Where did you find this sun shade? I can't seem to locate them.
P
pappyo
597
2,400
Heat & Air Pressure Problem with : OEM Hard-Coat bottom tip-out -- Roof & Hard Kolpin Rear Panel with( P520 DOORS).
Installed Vent in rear panel of Roof. (Pictures)
Towing :
Tip Vent opening to bottom ( downward Air Flow )
All windows & doors Closed does a good job reducing Cab air pressure while Towing.
Reduce Cab Heat :
Tip Vent opening up (upward Air Flow ) & Open Tilt Windshield at Bottom.
Allows decent upward Air Flow & with door windows open -- maintains decent air movement & several degrees cooler.
Not as good as A/C although does make 90° day more comfortable.
20210306 165657 20210306 170039 20210305 173001
Reactions: Bigtee
