My shop is an authorized Carrier dealer, I was impressed with there equipment as an HVAC tech before I worked for a shop that carried them. I’ve seen and worked on a few of there RV roof mounted units and there of good quality imo. Domestic and Coleman make decent units as well. They all typically use 2 different brand compressors and both are good. For your set up, your looking for a unit that has the controls (thermostat) on the system itself, that would be easier to deal with. The ladder you would have to run stat wire and a thermostat on the wall. All of the RV roof mounted units use 110v so you can plug that directly into a dedicated portable generator to run it.
