P1000 Rough Country Lift
jpanicaro
38
111
SWFL
Hi everyone, I am getting ready to pull the trigger on the Rough Country 3" Lift for my 1K5. I have searched and only found 2 users running this lift. Is anyone else running this lift? If so how do you like it? My plan is to run 1.5" wheel spacers all the way around for a wider stance as well. Thanks everyone!
Reactions: TxDoc
Gabbas
Gabbas
280
700
Humboldt, Iowa
Just a heads up. Bracket lifts ride like crap. Just from what I've seen and others have wrote about. I don't personally have one installed. But I have the 3" Super ATV bracket lift sitting in a box in my shed, hesitant to put it on.
Sent from my Pixel 4 using Tapatalk
jpanicaro
38
111
SWFL
I assumed bracket lift would ride better than a spring spacer as adding a spacer changes your spring rate and preload.....
Gabbas
Gabbas
280
700
Humboldt, Iowa
Changing the angle of the shocks in general which is what a bracket lift is, compresses the shocks and adds lift.
Reactions: TxDoc and jpanicaro
JenElio
JenElio
65,213
610,086
Loxahatchee, florida
Spring spacers are not that bad, I put mine in about 6 months ago and its not that bad at all
Reactions: jpanicaro
CGD
CGD
SE Missouri
I put spring spacers on mine about 6 weeks ago and I actually think it rides better. I have a good mixture of pavement, gravel, and trail time on the machine and my wife even noticed the improvement.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
I wouldn't recommend the lift...ive had both lift and spacers. If you're looking for clearance go with the spacers. Lift changes the geometry of the shock and ride quality goes to hell.
Reactions: BigOL3
