P1000 Stock P1000s that ride rough
ODAMO
ODAMO
1,287
3,463
Ohio
I had to replace a ripped rear axleshaft boot and in doing so discovered an interesting situation.
In the manual it explains how the a arms need to be torqued at the frame mounts at a certain shock eye to eye dimension. That dimension happens to coincide with the vehicle being at ride height. What I discovered was that the a arms on my unit were actually torqued at full droop, not ride height. I have my rear shocks at preload 1 and always thought it rode rather stiff. At ride height each a arm was creating additional downforce because the bushings are bonded and therefore were in torsion when they should have been in a neutral state. I estimate the force per a arm was about 15-20 lbs. resulting in 60-80lbs. total effective additional spring rate on the rear. After loosening the a arms, rolling forward and back to settle suspension and retorqueing them at ride height it does indeed ride a lil smoother. Not fox shock smooth but smoother.(if the fox shocks also have bonded bushings they too would benefit from checking the intallation)
So, anybody that doesnt like the ride quality of their unit might want to check their bushings. When you loosen an a arm mounting bolt at ride height if they were torqued at droop you will hear the bushing unload while you loosen it indicating they were wrong.
I do want to give a shoutout to @joeymt33 for his video on cv boot repair. His tip on tapping out the cv ball cage assy. saves time and money if you only have to repair an outer boot. Thanks for the info.
I’m glad the video was helpful. And that is a good note on the bushing pre-load.
WagginTail
WagginTail
1,585
5,880
SC
What is the torque spec on the a arm bolts? I never knew that could be an issue. When I installed my SuperATV arms I probably tightened the bolts while the pioneer was on a jack. I know I didn't torque them.
I've been noticing a slight clunking noise in the front end lately. This past weekend I figured out the left front upper a arm bolt moves side to side when I roll the front tire back and forth quickly. Might be time to do the upgraded a arm mounts?
Scoop
Scoop
5,191
20,513
  3. Talon R LV
These are from the 2016-2020 service manual.
1694130942206
TripleB
TripleB
15,618
140,491
Caryville, Tennessee
Bushing could be wore already. Top one seems to wear the quickest.
WagginTail
WagginTail
1,585
5,880
SC
Maybe. But the bolt shouldn't move side to side in the hole of the frame should it?
Reactions: JenElio
JenElio
JenElio
75,053
677,066
Loxahatchee, florida
It shouldn't, no. But it wears out the hole in the tab. You need to get the washer/bolt kit and reinforce that area. Mine has same symptoms, I need to get it done sooner then later.
WagginTail
WagginTail
1,585
5,880
SC
Yea that's what I'm thinking. Also I think I seen someone on here upgrade to a 12mm bolt. Might do that as well
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
RB3 has new kit they just worked on with @ToddACimer
That's the one I'm leaning towards now...
Haven't proven it to be more reliable yet but I'm trying. I have about 200 miles on the 12mm setup and it is still tight. I've broken 10mm grade 12.9 bolts in less than 1000 miles. The 12mm upgrade sounds better for sure and feels tighter.
PXL 20230719 005523344 PXL 20230719 005526240 PXL 20230718 221738993
someguy1313
someguy1313
237
518
SouthEast
very interested in the A Arm upgrade kit...
will this be upper and lower? and will this have weld in/bolt in gussets?
I think who ever makes a complete kit that's a pretty straightforward install strengthing the uppers and lowers will sell a lot of them.
Reactions: JenElio
JenElio
JenElio
75,053
677,066
It's just for the uppers, not gussets. There's lots of info around here on adding all types of gussets to reinforce different areas as needed.
I don't think you could make a "straightforward install kit" for gussets. It's all gotta be welded on, I mean yeah they could sell you the gussets but if you already have the knowledge and tools to weld it all your self chances are you have some steel laying around you could use to make them as well.....my 2 cents
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
My build thread highlights how I did the gussets on the uppers and lowers, as well as the welded washers on the tabs and then the 12mm bolt upgrade. It's definitely easier in my opinion to start with some 2x2x1/8" tube and cut the parts you need . It could be manufactured but in the end you want to test fit the parts and bolt them in place for welding. Depending on your front bumper setup the front upper gussets need to be place around the mounting feature for the bumper. Most aftermarket bumpers mount outside the frame unlike the stock bumper that slides inside the frame.
Reactions: Scoop and JenElio
