Talon running in low
Scooter14
6
5
Pittsburgh,Pa
So, since the Talon has an auto transmission, whats the purpose of "low range" on the shifter? Does the tranny just stay in low gear the whole time or does it still shift in lower ranges? Probably stupid question but my question none the less.
Thanks in advance
Reactions: Russ989 and BWAF
justin2959
14
US
So for trail riding would that be the best way?
I go when i know im just going to be out cruising 15-20 mph. It will run up to around 40 mph or maybe a little more but if your running that fast high range is better. More of a rock crawling to cruise range.
Reactions: BWAF
Scooter14
6
5
Pittsburgh,Pa
Thanks for the in put
Reactions: justin2959
Vondy
Vondy
1,535
10,159
Houston,OH
  1. Talon X4
I generally run in high unless its a rough slow trail or a tough obstacle, then I put in low.
Reactions: BWAF
HUCK
HUCK
1,047
2,319
ARIZONA
If you only use high , you have 6 speeds . If you use both you have 12 speeds . Use both then you get maximum fun .
Russ989
Russ989
22,642
147,257
Thanks in advance
It gives you 6 more reduces gears by using a sub-trans.
Cobweb
Cobweb
67
172
Hexi Hollow
In the woods I run low. If i get out on a road, then high. At Hatfield McCoy last month I ran in low almost all the time. You're good in low up to 35-40 mph.
Reactions: CumminsPusher
