P500 Rusty's Juicebox #nohomo
rustyneversleeps
rustyneversleeps
383
1,835
Montana
Finally got the mofo home today, blue is slowly growing on me. I've got a lot of plans for it - locker and EPS in a few weeks and more along the way. Kinda makes me a little sick to start tearing into it 🤣. Will update as I go. Thanks for everyone's help and advice so far, this a great place.
P.s. Red is the fastest, green is the toughest, but blue is the most badass 🤣
Pioneer
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,118
21,315
Route 66 Oklahoma
Blue is definitely badass. 👍
Blue
rustyneversleeps
rustyneversleeps
383
1,835
Montana
Took two days, but got the seatbelt bypass done...
PXL 20210520 201345121
Most of the time was spent fiddle f***ing with pins and screws. Should have taken about an hour with most of the time spent taking the panels off....
179,041
Lol, I can have my plastics out in minutes. It'll be a lot easier now that you've done it once. Having the right tools helps too.
rustyneversleeps
rustyneversleeps
383
1,835
Montana
🤣 ya once the GreenGoat got me on track, it was like a lightbulb moment haha. I'm slowly putting together a "pioneer toolbox" to help with that also. If you have any tools or sizes off of the top of your head, I'll add them to my list. I took the door nets off yesterday, but forgot the size of the bolts. I'll have to make a note. So far #3 phillips and extra pins are on the way...
rustyneversleeps
rustyneversleeps
383
1,835
Montana
Got the reverse bypass done tonight, was simple and works great...
PXL 20210521 235009726
Just double checking, but is this where the sub harness plugs in?
PXL 20210521 235503993
PXL 20210521 235511975
edit - found it on @The Green Goat s build
179,041
Bigtee
Bigtee
556
1,213
Grayson, KY
It plugs in where you have it. I taped the connection up good on mine after I plugged it in. Also you may want to zip-tie it to the other wires so it isn’t hanging down.
rustyneversleeps
rustyneversleeps
383
1,835
Montana
Back to rookie questions...this time on wiring. I've kinda got 7 or so accessories/switches I want to work with. I'm not positive on how to wire the accessory to the switch and back down to the fuse block, but I'm a pretty visual dude, so wondering if you guys can critique my sketch? I'm not sure if I'm missing anything here...would like to have the rear winch/tiger tail removable and also plan on tying in a rear license plate light directly into the rear taillights. Any advice/ideas/guidance/do's or don'ts or telling me I'm a dumbass...all ears 🤣 Thanks guys
PXL 20210522 175914025
The Green Goat
The Green Goat
2,194
16,253
Ohio
Rustywiring
Updated.
All your accessories need to be grounded. You can do this by either tapping a wire into the metal frame, wherein the frame acts as the return wire, or you can run a physical wire back to either the negative battery terminal, or your fuse block, so long as the fuse block is also grounded to either the battery or the frame. You have to create a loop of electricity or it won't 'flow'.
Same goes for switches. If the switches have a backlight, then you need to wire them as an accessory as well. The switch backlight will also need power and grounding.
rustyneversleeps
rustyneversleeps
383
1,835
Montana
@The Green Goat thanks a lot man that helps for sure. Is there a "ground block" that I could just attach to the frame somewhere and run all of my grounds to that so they are all in one place? And just want to make sure I'm understanding - I run one negative wire from the fuse block to battery and a second negative wire from the fuse block to the "ground block"? I didn't even think about power/ground for the switchlights. Maybe I should just stick to non-backlit switches for the simplicity (14 more wires for just the backlights on the switches?) Thanks again for you help! I just wanna do this right the first time...
The Green Goat
The Green Goat
2,194
16,253
Ohio
There are bus bars/distribution blocks out there of all flavors and variations. I got mine on Amazon. You could choose to run them all to one central location, or tap into the nearest frame bolt if you'd prefer.
You could also get by with only 2 wires (+/-) for the switches if you daisy chain them together.
rustyneversleeps
rustyneversleeps
383
1,835
Montana
Finally getting this thing put together. Got the UTV801 windshield installed - great guy to work with and fastest shipping of everything I've ordered so far. ATV/UTV Tek side mirrors and a cheap electronic horn that surprisingly works well and is loud.
PXL 20210606 162155728
PXL 20210606 162234847
PXL 20210606 162630282
PXL 20210606 162848277
rustyneversleeps
rustyneversleeps
383
1,835
Montana
The HTRs all finally arrived, ordered 4 from Dennis Kirk, but was notified one was backordered. Had to pick up another front from Lionparts, since most places are sold out or way more expensive. 27x9x12 on the front and 27x11x12 on the back. Supposed to be about 60 days until the rims arrive, so they will be chilling in the garage for a while.
PXL 20210606 163557996
PXL 20210606 163545037
