P1000 S&S Fab skids - anyone using them
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I priced doing my UHMW and even did a CAD drawing. My buddy and I planned to make a day out of it in the shop. By the time I bought the material needed it was still more money than the S&S. Not to mention all the time it would've taken piecing everything together and figuring out where to place the holes etc. It was a no brainer for me...
It was a no brainier for me for the exact opposite reason. The center belly is easy as the stock skid plate hits all the holes except the front 4 for the plow bracket. I also avoided making pieces across the width of the machine to prevent getting hung up when transitioning from 1 piece to the next
I didn't make my own a-arm guards due to the compound angle and bend radius but I think I'd give it a shot if I had more material.
Flat layout
IMG 20161230 124150678
Center belly fitup for front mount layout
IMG 20161230 160044336
IMG 20161231 124332310
Side panels. The center belly is 1.5" wider per side than the square tube frame which allows the side panels to be tucked above the center belly. The leading edge of the side panels and the center belly are rolled to protect the wimpy stock rock sliders and square tube frame rails
IMG 20161231 124504316
That's exactly the conclusion I came to.. I should have laid the aluminum skids out and patterned them though. That would have been handy for anyone wanting to build their own out of either material.
Reactions: cruddy0815
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
I have all the hole locations and hole sizes drawn and dimensioned on my full-size layout but I never transfered them to a legit scale drawing. I could easily make another plate in UHMW or aluminum. I had taken dimensions of the machine before I started so the center belly plate was cut to 30x96" and the remnant was cut to 16x96" for use as the side plates.
Reactions: cruddy0815 and JTW
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Understandable, but for me $440 total (for the S&S skid) and less than an hour installation was too good to pass on. If I don't save a significant amount I'll buy and save my time and headache. However, I will say you saved a ton vs a UHMW skid purchased somewhere.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
The nicest part about UHMW, is it doesn't put much wear on your cutting tools, ha. Just need to cut right the first time or it's a pain to get back to a straight/square edge.
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Yeah I heard that when I was researching. Several said it was very similar to working with wood.
Boomboom907
596
620
Washington
Might be worth applying the top of the skid plate with some kind of waterproofing spray. It might help the mud roll out when you give it a spray or drove through a river. I don't know how long it will last though
Sent from my Pixel XL using Tapatalk
@cruddy0815
Several have opted for S&S a arm guards.. and UHMW belly.
I went with the whole S&S package.. so far I'm pleased by both.
cruddy0815
cruddy0815
50
146
Northern Michigan
@cruddy0815
Thanks for the update JTW! I'll be researching and most likely trading $ for product!!
