That’s a good idea. I’m going to get a rubber boot similar to that and put it on top of the center console with an aluminum mounting plate. The shifter is so short, I may need to extend it a little bit. I don’t think your style will work on the Talon since the shift cable is mounted on the side of the tunnel. Amazingly enough the plastic console top is only $9 shift shaft is $12, so if I screw it up, it’s cheap to replace.Her's what I did on my 1000-3. It requires dash removal, but it's a permanent solution.View attachment 177103 View attachment 177104
Maybe, but I don’t think the slit will stay closed.Would a piece of tire tube (about 4" x 10") fastened to the bottom of the shift gate with one lengthwise slit work for this? You wouldn't need 'gates', just a 10" (?) long slit.
fwiw: I don't own yet but spent 3 days riding in a Talon at the SxS rally at Sand Hollow.
Taking it a step further - two lengthwise strips with 'a lot' of overlap might work better.Maybe, but I don’t think the slit will stay closed.
The difficult part is getting the shifter knob off.Thanks. Then experimenting should be pretty easy.
