Talon Shift gate boot
K
KenThompson
265
603
Mulino
Does anyone make a shift gate boot to eliminate dust from coming up thru the holes
DAJO
182
125
Indiana, Arizona
Dust and heat both come up around the shifter. No boot available that I know of. I would be first on the list to buy one. Meantime have used foam cut to fit around shifter and slotted for shifter movement under the shifter gate and top cover.
Jefferson87
Jefferson87
258
275
Northern California
I'd like one for winter use.
I tried cutting some rubber with a bunch of flaps, but all I had was 1/8" which was to thick and stiff.
russknight
russknight
1,910
7,507
Perry Florida
Her's what I did on my 1000-3. It requires dash removal, but it's a permanent solution.
Shifter
Shifter2
Reactions: BWAF and CID
K
KenThompson
265
603
Mulino
Her's what I did on my 1000-3. It requires dash removal, but it's a permanent solution.View attachment 177103 View attachment 177104
That’s a good idea. I’m going to get a rubber boot similar to that and put it on top of the center console with an aluminum mounting plate. The shifter is so short, I may need to extend it a little bit. I don’t think your style will work on the Talon since the shift cable is mounted on the side of the tunnel. Amazingly enough the plastic console top is only $9 shift shaft is $12, so if I screw it up, it’s cheap to replace.
5,057
22,683
Would a piece of tire tube (about 4" x 10") fastened to the bottom of the shift gate with one lengthwise slit work for this? You wouldn't need 'gates', just a 10" (?) long slit.
fwiw: I don't own yet but spent 3 days riding in a Talon at the SxS rally at Sand Hollow.
Reactions: Lil_Steve
K
KenThompson
265
603
Mulino
Maybe, but I don’t think the slit will stay closed.
Reactions: CID
bjniceguy
322
431
Iowa
if you look down thru the shift gate, you can see all the holes in the factory skid plate. When I added an aftermarket 1/2" skid plate, it helped a lot with the dust. It does hold the heat in more so next summer I may regret it LOL
Jefferson87
Jefferson87
258
275
Northern California
I'd be worried about the slit method messing with proper gear engagement. But I guess I already have that issue with no rubber.
I may try again with the 1/16" thick neoprene I have coming. I wonder if 2 separate pieces curved down parallel to the shifter might work better?
5,057
22,683
Two separate pieces curved down parallel to the shifter might work if they were fastened close enough together to keep them touching. About messing with gear engagement - 'in gear' is toward the driver, maybe that could be favored when fastening them.
Is the plastic gate itself fairly easy to remove? Or is it the entire console?
Reactions: Sheetmetalfab
5,057
22,683
Thanks. Then experimenting should be pretty easy.
