Shift Lever's stopping air flow
slowdryrider
slowdryrider
574
784
Canada
Went for a ride today and have come to the conclusion that once my cab is completed and the heater is installed,I'll have to try to figure out away too stop the cold air comming in through the lever's. My question to anyone who has installed there heater is have you figured out how to stop the cold air comming in around them. I have some idea's but just wondering if anyone has it figured out already. I've already closed the gap around the brake and gas pedal.I accomplished this by unbolting and removing both pedals then sealed the gap with silicone.Any air leakage anywhere defeats the purpose of having a heater,so I need to stop all cold air leaks that I can.
Reactions: Montecresto
binfordw
131
10
I recently noticed the same issue.
I think thin rubber "donuts" secured around the levers behind the dash will work. Might be tight trying to fit in there and mount em though, I haven't looked yet.
F
farmer700
80
could make some kind of sliding plate on the bottom side.
binfordw
131
10
I had a quick look at the backside of dash and ordered a sheet of rubber, I'll post details when I finish.
Reactions: Hawk53
daberry
68
Kansas
Just got my front doors on yesterday. Took a cruise today and the air coming in around the pedals and shifters is now very noticeable. Still it was 15 F with a 30 mph wind so the cab was VERY nice to have. :)
binfordw... appreciate whatever you find that works.
Dale
Hawk53
Hawk53
485
622
Alberta Canada
Were you able to do anything with the rubber sheet behind the dash ?
