P500 Shift On The Fly
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
Not sure if it's been ask but the manual says we have to stop in order to shift in 4WD ...
I think i did this once since the bike is new and after reading the manual it says
Is it ok to do this while driving or do i really have to stop before attempting a mud hole and then shift in 4WD or vise versa into 2WD ...
The old 2013 420 DCT i always shift on the fly..
13,361
65,099
In my personal machine.... I do exactly as written in the manual....
Ok, now that the lawyers stopped reading. I shift on the fly as well. But only under certain circumstances.
I have to be traveling in a straight line.
I have to be coasting. never under power.
Only time I come to a complete stop is when I change from high to low on mine.
63,560
Same here, slow speed, no throttle, straight.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Personally, I do it like described above and just use common sense when do it... That is, I would not switch when the unit is in a bind, turning or calling on it, etc., but rather when under no load/torque to really speak of.
70Bones
70Bones
888
3,779
New Brunswick Canada
Now that my warranty is over... I echo what is mentioned above. I switch from 2-4-2 on the fly, but never when there is load on the drive train (not accelerating or braking), and usually at lower speeds.
Did you ever drive an old VW with a broken clutch cable? I drove one for quite a while with no clutch cable, and like most standards of old, you could easily and smoothly shift gears by taking load off the drive train. Do that with the 2/4 WD shifter.
41,798
What others said: Utilize some common sense in regards to matching wheel speeds, and shifting on the fly is fine.
Reactions: Rustneversleeps
