T
Have a 2018 sxs 1000 5. Huge lag when it shifts and it will not relearn the clutches. Have replaced the oil pump and clutch packs. Replaced the pump because oil pressure dropped hard and the rear pump had bad wear. After installing the new parts test drove it and it has a huge lag spot between shifting (engine revs to the moon then shifts)
Have tried to reset the clutches least 30 times so far. Have noticed that then starting the relearn that when I go from park to low it don’t want to indicate low right away and some times have to rock the machine to get it there
Running 10/30 oil and new filters.
Any help you guys may have would be awesome
