P1000 shifting issues
silverbullet
16
Leitchfield, KY
Having issues with my shifting in MT and AT. It runs at high RPM before shifting and shifts into gear hard. Anyone experience this or have any ideas to fix it?
63,527
Welcome to the club @silverbullet.
We need to know how long have you had it and how many miles do you have?
The hard shifting is common with a new unit. As it starts to break in it will quieten down. After your oil change it will be great. Until then when it changes gears it is very noticeable. Almost like something is wrong with it.
About the high RPM's. Can you describe this more.
thanks.
silverbullet
16
Leitchfield, KY
Its already broke in. Had my first oil change about 6 months ago. The high RPM thing is when it shifts. The RPM is higher than before it shifts. Where before it felt right when it shifted. It also feels like i have to push the gas pedal down a lot more before it starts moving. I would go as far to say it feels like t's slipping than catches than moves or shift to the next gear. Never did this before. It started last week when my wife ran it through a mud hole.
Reactions: pct
amc019
amc019
480
592
Little Rock, Ar
Have you had your vent lines extended? If not, you might have water or something in the trans/sub trans. Or even an electrical issue that some have faced.
Reactions: pct
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
Did your wife have it in High Range and get stuck and really hammer it trying to get out? Particularly in Reverse? Do you have heavy/larger than 27" diameter tires?
If so, you likely have a burnt clutch. A symptom of that is a RPM spike just before shifting as the glazed clutch plates don't have the same coefficient of friction that they previously did and they spin until the clamping force of the transmission is great enough that it causes them to "bite" and engage.
Before I got carried away though, I would check some of the things mentioned above and make sure that your oil isn't contaminated, make sure you don't have any loose grounds (under the driver seat rubber flap), and maybe even do the clutch initialization procedure. However, assuming you are still under warranty, I personally would probably take it to the dealer and let them look at it first and see if anything could be covered under warranty.
If it is a burnt clutch, Honda needs that data point to make sure they get a fix in place. People will take these things in the mud and people expect the same level of reliability as the Rancher and the Rubicon, that is why they buy Honda.
Reactions: pct
Bayouownbeer
Bayouownbeer
786
1,061
Chauvin LA
You have to do the steps quick for it to work
IMG 7810 IMG 7811
