P1000 Shock upgrade
207,989
Looking for some advice.. was going to put super atv 1.5” high clearance arms on my P1000-5. Looking to also upgrade shock and was wondering best route and also trying not to spend crazy money
If I had to do it over, I would go with fox's, keep the stock A-arms and just ride. The Accessory A-arms put stress on the the frame attachment points that aren't designed for that stress, that will save you $ 1,000.00 easy. The non factory A-arms don't have the rubber bushing in the A-arms. You have winch, if yes use it if you get hung up and get some recovery equipment. I suggest you do a lot of reading about shock set up before you buy a set of shocks. You will never make a P1 into a RZR, but shocks will improve the ride. What kind of shocks do you have now?
Robobrainiac
Robobrainiac
2,464
8,600
Since you are asking here is my opinion:
I would suggest you set an expectation of how you want the machine to ride. Then prepare to open your pocketbook. Suspension is not cheap. If you want a better than stock ride with the capability to add lift using pre-load then I recommend rough country if you are on a budget. If you want a great ride then grab some fox shocks and be prepared for some potential coil swaps for $2k. If you want one and done call elka with ALL of your vehicle specs, including every little thing even down to a cooler and be ready for a maximum hit of around $5k if you want the best. Any/every other brand is just money spent on something that might make you happy and will waste your money in the long run.
Bama-Daniel
Bama-Daniel
698
6,882
Priceville, Alabama
Agree on everything you said. Foxs are probably best bang for you buck and will give you a much better ride than stock.
Scoop
Scoop
4,239
15,883
  3. Talon R LV
Last time Ron Ayers posted here, they were $1,469.00. Viper coils are $70 x2 for the fronts (250#) and $85 x2 for rears (300#) on Amazon. So the cost for QS3's and coils today is $1,779-ish.
I haven't done much hard trail time, but since swapping out my OEM bits for the above, I can already tell a marked difference in performance.
L
LarryAmboy
894
1,979
Castalian Springs, Tennessee
Elka Stage 5 - buy once, cry once
207,989
Did you catch the terminology of fast and slow speed damping adjustments the first read of the owners manual, I didn't.
Reactions: Backwoods
