P1000 Should i buy this Pioneer
Madisonhunter
6
9
MS
This will be my first sxs and I’m looking at a 2016 Pioneer 3p non eps. It only has 140 miles on it bc the guy just uses it in his 10 acre lot/house. My question is, with all the recalls and issues i see, should i buy this machine ?? My budget is low and i can get this one for 9k. It has no roof or windshield. It’s looks brand new.
Reactions: sharp and 100Acre
It’s a Pioneer 1000? That’s probably a fair price, it probably needs the air intake mod, cabin heat mod, clutch mod and muffler shield mod, you might look for that.
Reactions: sharp
67,170
Not too shabby.
If its clean underneath it's a good buy.
Call your dealer and schedule all the recalls and updates. Have the clutch update done no matter there suggestions.
Air intake update will need to be paid for. Its $10 or so.
Clutch update.
Hear fix update.
Muffler recall.
Throttle body recall.
Check door handle and balancer recall.
What did I miss?
Reactions: sharp and Remington
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
That's a steal. Dealer will do the recalls no biggie
105,572
Welcome to the forum from LaLa Land. Who art thee?
Reactions: sharp and Eltobgi
Eltobgi
Eltobgi
4,599
15,186
North Dakota
If all maintenance and updates have been performed as recommended I would say go for it!
Reactions: 100Acre and sharp
sharp
sharp
3,757
14,955
Tennessee
Always make a counter offer.
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
Welcome from central Ohio.
If you have a good dealer to take care of the issues above, you should buy it. If you are concerned about buying one because those "product improvement campaigns" exist, relax. The majority of those are either assembly issues or "bullet proofing" a great machine. Just make sure you post some pictures and put a lot more miles on it than the original owner.
Madisonhunter
6
9
MS
Not too shabby.
Clutch update.
Hear fix update.
Muffler recall.
What did I miss?
It’s had all recalls done except the newest one - Throttle body. Can i still run it with out the recall? Until i can bring it in?
Madisonhunter
6
9
MS
F4170E49 C101 42B0 B14A 0720475E95BC E362B444 043F 45E5 9440 1BC31353C008 72619BA6 F46F 477F 8EE8 D1B55ECEFFC4
Firemedic530
Firemedic530
387
1,133
Yes, if you search on here you'll find the throttle body recall is just making sure they are seated and clamps tightened correctly. It pays the honda tech 15 minutes to check, I believe. You can pop the plastic shroud of the passenger rear and check it yourself easily.
Madisonhunter
6
9
MS
Spend $500 and install power steering. Other than that, make a ridiculous low offer and see what happens.
9k is the lowest he will go. Thought it was a good deal for 140 miles and 40 hours? Thanks again for all the help guys!
105,572
At least it's green...
Reactions: sharp and Mudwing
