Try a 7/16 -20 thread pitch. That's what the lap belt bolts are.Looking to use the shoulder strap mounting point on back of cage for light mount. Can anyone tell me the proper thread size for this? Have tried 10mm but to loose. Thanks
It is not a 7/16, have tried 10mm and 7/16. 10mm too loose and 7/16 too big. went to a local honda dealer and they couldn't tell me what size it is, does not show up on parts diagram.Try a 7/16 -20 thread pitch. That's what the lap belt bolts are.
I dunno then bud. If you have a tap and die set you could try different size taps to see which one fits. Without having a bolt in it I don't know what else to recommend other than thatIt is not a 7/16, have tried 10mm and 7/16. 10mm too loose and 7/16 too big. went to a local honda dealer and they couldn't tell me what size it is, does not show up on parts diagram.
Thanks for the help anyway.It is not a 7/16, have tried 10mm and 7/16. 10mm too loose and 7/16 too big. went to a local honda dealer and they couldn't tell me what size it is, does not show up on parts diagram.
Give me a min I'll go see if I can figure it outThanks for the help anyway.
Ok I just went and checked it is a 7/16-20. You'll more than likely have to chase the threads...mine had mud,rust,and powder coat in there.It is not a 7/16, have tried 10mm and 7/16. 10mm too loose and 7/16 too big. went to a local honda dealer and they couldn't tell me what size it is, does not show up on parts diagram.
Thanks for this! My 4 points just came in!
I went cheap.. I liked the buckels on these.Mine too! Ordered the beards like @Tramguage1 had at mulberry.
These are the ones I used. Me and the wife like them. I scotchguarded the pads so they didn't absorb a bunch of water.
Amazon.com: 4 Point Padded Harness with 2 Inch Pads E4 Certified: Automotive
Yessir I did.Did you just use the factory lower belt positions?
Yessir I did.
Yeah the only thing I ran into was I had to drill the mounting tab for the lap belt out a little bigger so I could use the factory shoulder bolts. And drill one hole in the passenger head rest.So basically a 15 minutes install?
??? Drill a hole in the head rest?Yeah the only thing I ran into was I had to drill the mounting tab for the lap belt out a little bigger so I could use the factory shoulder bolts. And drill one hole in the passenger head rest.
Got ya!Yep..like this.
