P1000 Side hilling angle of the dangle
ODAMO
ODAMO
1,177
3,206
The P1000 states 36* but that seems like a static number. realistically what degree of off camber side hilling is considered safe before a flop or rollover with stock vehicle?
Robobrainiac
Robobrainiac
2,464
8,600
That's like asking what size tire will fit. Honda puts that number on a stock machine. Probably on a concrete hill with no slip. Just changing tires could alter that number. Being in slop on a hill causing a sudden dip in mud could flop it. That is such a difficult thing to put a number on.
DRZRon1
DRZRon1
865
2,806
agree, that cramping hurting feeling in your belly that makes ya wanna get out and drop your pants or go around.
that number is under a specific test, too many variables as mentioned above - if it looks bad enough and need a body on the side as counterweight, its steep\off camber.........
JenElio
JenElio
65,062
608,976
Loxahatchee, florida
🤔......about 2° more then this 👇
IMG 2175
And then...............you get this 👇
IMG 28042
ODAMO
ODAMO
1,177
3,206
I’m just not used to 4wheel independent suspension yet. First sxs.
5,048
22,627
A Lev-O-Gage helps me know when I need to pay more attention BUT, as mentioned, the tilt table number is static and our environment is dynamic. As my tilt increases, my speed slows way the heck down, trying to minimize the dynamics. Even at the slowest possible speeds, I'm still getting a lot of dynamic input making the tilt gauge little more than a pacifier.
As a solo rider, I have to be far more careful than Adam490 who has a crew with him who can pull him back on his wheels.
Short version - if you're riding with others, it doesn't matter as much as if you're solo.
1672424364469
P
packer58
304
917
N. Cali
I'm still learning the limitations of my machine, i don't do very much technical stuff just for hunting mainly. I haven't taken off the rear sway bar yet as others have but got me wondering, once the sway bar is removed, does that help keep the front wheels on the ground through some of the technical twisting stuff ????
207,989
Yes.
