P1000 SikorskyGramps 17' P1K5 "Optimus" Build Begins
BJowett
Extreme Western Massachusetts
Welcome!
Snatch/stretchy straps are just a bad idea, they break both parts and people. If a tow/recovery strap will not dislodge a stuck vehicle, we winch. Red Art Speed Speed Straps are my favorite tow/recovery strap... they can quickly be adjusted to any required length.
Boomboom907
596
620
Washington
Welcome!
We love stretchy ropes. Seems like it puts less stress on everything including your neck. Allows the other rigs to get a running start instead of taking the slack and then just digging down.
We see waaaaay better results with stretchy over rigid.
Guess its all just personal opinion.
But who wants to pass an opportunity to say they had to yank out their buddy?
Sent from my Pixel XL using Tapatalk
BJowett
Yes, they work very well, and that is because the forces they create are immense... Many times greater over a straight winch pull. So the likelihood of failure goes up, and when it does happen, the power behind it is far more destructive. Just be careful!
Boomboom907
596
620
Washington
Nothing ever goes wrong in the woods anyways
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
I've had good luck with the Warn snatch block! Never have used kinetic but have a variety of ropes and straps that I always carry! Still running stock bumper so have to get creative if I don't want to use the winch to get out!
That Warn Epic snatch block looks really nice. $40 cheaper than the ARB as well!
Reactions: Eltobgi
ToddACimer
ToddACimer
Pioneer 1005-2
3,745
15,859
Oshkosh, Wi
Got the Factor 55 recovery receivers and 4.5T Crosby shackle installed in the back today. The other one will go into the front of the Tough Country bumper when it arrives.
Looks like Honda beefed up the rear hitch for 2017 and removed the vertical hitch pin hole
Reactions: JTW
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
Had a great day working on the machine today. I got the trail armour skid plate and a-arm guards installed today. My friend was kind enough to use his mini excavator to roll he machine up on it's side in his shop. I pre-drilled pilot holes for everything on the bottom and used Loctite. I noticed the frame was super solid but the tubing on the outside edges seem thin in comparison. When I rechecked all of the screws afterwards I realized I had stripped a couple of them in the thin metal tubing. It's off to the hardware store tomorrow to buy the next size up stainless sheet metal screws. The a-arm guards went on without issue and I'm really pleased with the coverage the whole package offers. One thing to note, one of the wheel studs had partially stripped threads. This was the first time the wheel had been taken off since brand new. I cleaned up the nut and stud with a tap and die and some oil.
Here's some pictures of the fun today in the shop.......
IMG 0569
IMG 0572
IMG 1533
IMG 0567
IMG 1535
IMG 1552
IMG 1553
IMG 1536
IMG 1559
IMG 1560
IMG 0571
IMG 0568
ToddACimer
ToddACimer
Pioneer 1005-2
3,745
15,859
Oshkosh, Wi
Another option for the stripped screws would be to drill out the holes for a 6mm nutsert and use bolts. Below are the links for the parts I used to bolt up my skid plate.
Nutserts
Muzata 100Pcs Zinc Plated Carbon Steel Rivet Nut, Threaded Insert Nutsert Included M3 M4 M5 M6 M8 Muzata 100Pcs Zinc Plated Carbon Steel Rivet Nut, Threaded Insert Nutsert Included M3 M4 M5 M6 M8: Amazon.com: Industrial & Scientific
Flanged bolts
Pit Posse 25pc Piece Metric Flange Bolt Motorcycle Street Dirt Bike 6mm M6x20mm Amazon.com: Pit Posse 25pc Piece Metric Flange Bolt Motorcycle Street Dirt Bike 6mm M6x20mm: Home Improvement
Reactions: Corona1
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
Hey Guys,
Well, the bumper was an epic install - it took 3 of us beating on it with a sledge hammer - bent the lower mounts out a bit but since it was securely welded on both sides, it still wouldn't go onto the frame all the way (TC just built it too tight) So I took the 5" angle grinder and ground about 1/16th of an inch off the inside of both brackets and Voila! - it slipped into position with a little more persuasion from the sledge hammer! I spray painted the bare metal and used thread lock on all the bolts. The TC kit was also missing the 4 "spacers" that went inside the hollow frame to avoid crushing it when the 4 bolts were tightened up (the Honda bumper had the spacers welded inside the bumper mount. Anyway, I was able to make two out of a piece of heavy aluminum square tubing and two more out of some 1" round heavy gage pipe. All painted to prevent rust. As you can see, the bumper is an absolute thing of beauty!!!!
One other problem, the Honda winch bracket is of no use to mount the fairlead plate. I will order that KFI one for $29, or I could have the local machine shop bend up a plate...... If it went under the 4 winch mount bolts and was bent 90 deg and made strong, it would do the trick! Anyway, very pleased with the results so far!
WP 20170311 09 24 52 Pro
WP 20170311 09 25 24 Pro
WP 20170311 09 35 37 Pro
WP 20170311 09 38 28 Pro
WP 20170311 10 06 20 Pro
WP 20170311 10 34 06 Pro
WP 20170311 16 59 02 Pro
WP 20170311 17 00 01 Pro
WP 20170311 17 00 21 Pro
WP 20170311 20 34 01 Pro
WP 20170311 20 34 17 Pro
WP 20170311 20 34 33 Pro
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
So......I decided to build a wooden cargo box out of 3/4" ply to fit in behind the rear seats when they are raised. I wanted something with a hinged top that would keep the water and trail mud off. I'll be using it for synthetic rope winch extensions, shackles, snatch blocks, shovel, axe, splitting maul, etc. I'll paint it all up gloss black once it's done. I'm planning on using a full length piano hinge as well. I'm really enjoying the build so far!
WP 20170311 11 19 14 Pro
WP 20170311 11 53 39 Pro
WP 20170311 12 05 49 Pro
WP 20170311 12 06 15 Pro
WP 20170311 12 07 28 Pro
WP 20170311 12 07 38 Pro
WP 20170311 12 08 05 Pro
WP 20170311 12 09 05 Pro
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
Couple of shots with the Factor 55 recovery receiver and Crosby shackle. With one snatch block I should be able to winch the damn thing straight up a tree...............completely eliminating the need to take the food out of the Pioneer for bears :)
IMG 0634
IMG 0635
IMG 0636
IMG 0637
IMG 0638
Couple of shots with the Factor 55 recovery receiver and Crosby shackle. With one snatch block I should be able to winch the damn thing straight up a tree...............completing eliminating the need to take the food out of the Pioneer for bears :)
View attachment 38096 View attachment 38097 View attachment 38098 View attachment 38099 View attachment 38100
I like like like it!! Get a wireless remote if you're going to winch the pioneer up the tree... going to be hard riding with splinters in you're ass after crawling up and down to raise and lower it!
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
That's some funny sh$t there JTW :) I didn't know they made wireless remotes for the smaller winches. Something more to checkout for sure. I can't keep up with this damn forum and all the mods guys have done to their machines. The last couple of feet of snow should be gone in another two weeks or so. Can't wait to get this thing muddy like it should be!
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
The rear cargo box is coming together slowly. I used my router and cut out spaces to access the latch mechanism for the rear seats. There's also a second notch cut in for the tailgate cables to neatly fold in out of the way. Top Piano hinge is on as are the foot spacers on the bottom. I've got an axe, shovel, straps and shackles in there with lots of room to go for a few snatch blocks, Pull-Pal and some saw pre-mix fuel. I'll paint it black this weekend and that about do it.
WP 20170315 11 55 54 Pro
WP 20170315 15 24 20 Pro
WP 20170315 15 24 34 Pro
WP 20170315 15 29 05 Pro
WP 20170315 17 15 17 Pro
WP 20170315 17 15 33 Pro
WP 20170315 21 37 44 Pro
WP 20170315 21 38 05 Pro
Similar threads
Replies
Views
256
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
2K
