P1000 SikorskyGramps 17' P1K5 "Optimus" Build Begins
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
I backed the Pioneer out of the garage tonight and flipped the LED stock headlights on for the first time. I couldn't believe how bright they were! I'd love to see the output of one of those 48+ inch LED light bars everyone seems to have on their rig. I've read on here that a few guys can't even tell if the OEM lights are on or off when their light bars are on...........must be crazy bright. That mod will have to come down the road a little bit I think :)
Here's the stock lights on low and high in my driveway with 18" of snow still to melt on the front lawn..........
WP 20170315 21 45 03 Pro
WP 20170315 21 45 25 Pro
WP 20170315 21 45 37 Pro
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
I
View attachment 38329 View attachment 38330 View attachment 38331
I had to adjust my lights downward a good bit. I have a 52" light bar and when it's on you can turn on and off the headlights and can see a difference. I turn on the headlights just so the back lights are on.
Reactions: Corona1
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
I
I had to adjust my lights downward a good bit. I have a 52" light bar and when it's on you can turn on and off the headlights and can't see a difference. I turn on the headlights just so the back lights are on.
Reactions: SikorskyGramps
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
I
Excellent tip........thanks Deer-hunter.
nbomar
nbomar
4,416
17,854
Springdale, AR
How much overall length did the TC bumper add @SikorskyGramps
Dang. It would make it real right in the toyhauler. Not sure that's a good idea.
I think dad said his measures 10 1/2 with the rear EMP bumper and front TC. That's a Terra 45 for reference if that helps..
IMG 2382
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
WP 20170316 19 58 08 Pro
WP 20170316 19 58 28 Pro
WP 20170316 20 01 27 Pro
Hi guys,
Just went out and measured it - it looks like about 6" longer than the stock bumper to the front edge of the pipe bumper frame, and 8" including the receiver. The massive part of this 126 lb bumper is mostly down underneath, making it look bigger than it is. Hope this helps!
Reactions: elkguide and JTW
Hi guys,
126lbs??? Really? Wow!
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
That was the shipping weight, probably 6 lbs of cardboard and tape - would still make it around 120 lbs. Took 2 guys holding it and me putting in the bolts ;) It now handles way better on gravel washboard though, with the extra weight over the front wheels.
Reactions: nbomar
Wow!!
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
I know. That bumper is ultra heavy duty compared to some of the aftermarket ones out there. The powder coating stood up to repeated blows with my sledge hammer when we were trying to mount it.
Reactions: JTW
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Got a quick coat of paint on the outside of the rear wooden cargo box. I'll throw on another one today and finish it off. I'm really pleased with the way it turned out. That'll be the recovery box for everything I hope I won't have to use. Winch straps, snatch blocks, land anchor, shovels, etc, etc
View attachment 38407 View attachment 38408View attachment 38409View attachment 38410 View attachment 38408
If you change your mind about storage you could always through to 15" subwoofers in it:confused:
Reactions: JTW
Yeah.. I just thought I'd was more like 80lbs
BigOL3
BigOL3
2,997
8,920
Hey Guys,
Well, the bumper was an epic install - it took 3 of us beating on it with a sledge hammer - bent the lower mounts out a bit but since it was securely welded on both sides, it still wouldn't go onto the frame all the way (TC just built it too tight) So I took the 5" angle grinder and ground about 1/16th of an inch off the inside of both brackets and Voila! - it slipped into position with a little more persuasion from the sledge hammer! I spray painted the bare metal and used thread lock on all the bolts. The TC kit was also missing the 4 "spacers" that went inside the hollow frame to avoid crushing it when the 4 bolts were tightened up (the Honda bumper had the spacers welded inside the bumper mount. Anyway, I was able to make two out of a piece of heavy aluminum square tubing and two more out of some 1" round heavy gage pipe. All painted to prevent rust. As you can see, the bumper is an absolute thing of beauty!!!!
One other problem, the Honda winch bracket is of no use to mount the fairlead plate. I will order that KFI one for $29, or I could have the local machine shop bend up a plate...... If it went under the 4 winch mount bolts and was bent 90 deg and made strong, it would do the trick! Anyway, very pleased with the results so far!
Glad I did not have that problem. It was a handful, but I installed my bumper by myself, and all the parts were there. It sure would have been simpler with some help ..... lol
Similar threads
Replies
Views
256
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
2K
