P700 Simple(ish) option for mounting lights
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
I got a 27" light bar awhile ago and have been going back and forth on how I wanted to mount it. I was afraid if it was on the roof, I'd tear it off. On top of the dash, it would vibrate too much. On the bumper, it would be too low. FINALLY here is what I came up with-
This bar attached at the roll cage joint and provides a sturdy place for lights with no permanent modifications. I will likely add cube lights to the sides later on since there is plenty of room. Still not quite finished in this pic but you get the idea!
I don't think that will be vibrating. Nice job, especially how it's removable.
Reactions: Tflynn
swsebek
swsebek
2,854
5,835
pa
now that's using xmas eve wisely..........Looks good.I used the same mounting location as well.
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Thanks guys! I'll get some more pics up when it's done
scott
scott
1,212
1,354
lyman, South Carolina
Mines on my hood but i'm going to have to move it once i get the front basket rack. Which might be awhile but i might just do what you did or something like it. Or maybe mount it to front of rack that will go on hood.
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Yeah if you run a rack on there you'll probably want your lights in front of it so if you have stuff piled up on the rack it's not blocking the lights
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Update-
Finally got it finished today and wired up. I wanted to show you all a few things I did-
I had to drill these 1" holes on the backside of the bar so I could fit a socket in there to tighten the mounting bolts. I didn't want to leave these giant holes open for water or other debris to get in so I plugged them up with these rubber plugs.
Reactions: AndrewsSeed
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
I also routed the wires through the inside of the bar for a cleaner look. If you do this, use rubber grommets!!
That is looking pretty good. And yes, the stock lights are now pointless.
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Thanks Joe. Next is mount some cubes on the the sides off at an angle like you have on your 1000. My goal is to have at least a 180 degree field of vision
The side cubes are cheap and a great reward for the price. I like mine so much, i almost think I don't need a switch. Just trigger the relay with the head light switch.
Gator
Gator
The Most Unknown Member
2,488
10,460
Louisiana
That looks real professional. I have it on my to-do list.
Reactions: Tflynn
d_b
d_b
302
240
Looking good @Tflynn. The cubes on the sides are much better in flood just a heads up. bought the cubes in spot didn't care for them, since purchased floods and hooked up to battery to see the difference, now just need to mount them hidden, protected. lol
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Thanks guys. I want to see your setups too when you get them installed. I'm definitely going with flood cubes @d_b, thanks.
