P500 Size Matters
sgerksinwi
sgerksinwi
203
264
WISCONSIN
Does anyone worry about the effect of different readings (speedo) when changing tire size?
Can you adjust it?
Sorry I do ride on trails with speed limits and I already give my DNR enough money
Jshell3
I've found larger tires are more accurate, according to my GPS.
I'm running 26's currently. They are close to spot on. The stock 24's were speedo faster than reality.
Reactions: JTW and sgerksinwi
Longbrake500
Longbrake500
96
168
Anna Ohio
If you are concerned I used to use a product called speedohealer on the bikes I changed gearing on and they actually list Honda pioneer on the compatible vehicle list.
Reactions: sgerksinwi
rocmar
rocmar
4,741
5,775
4 CORNERS
Can you adjust it?
Hahaha
never seen a speed limit sign
on a trail...
post a pic..bro
Reactions: Hondasxs
HUCK
HUCK
1,047
2,316
ARIZONA
If you changed to 35" tires it wouldnt make that much difference on a 40mph vehicle . just sayin
Reactions: sgerksinwi and JTW
A 35 inch tire on a P 500 with the speedometer reading 40 miles an hour would be approximately 53 mph actual speed. The tire size difference between 26 inch and 35 inch is a bout 25% difference so you will also have a 25% difference in your actual speed if the engine could do it.
That would be one bad dude though, wouldn't it? Could you imagine a P 500 with portals and 35 inch tires!? I would love to see you. However, a fart could knock it over.
Jshell3
One of my favorite websites. I won't hot link it, but here's a couple pictures comparing 24" to 26".
IMG 2708
IMG 2709
I tell my wife all the time... Size DOESN'T matter!!! Why on earth would a man title a thread as such????
Reactions: joeymt33
34,175
Shouldn't need to tell mama that.
rocmar
rocmar
4,741
5,775
4 CORNERS
35" tires.....
get it on video
gonna be a flop
Reactions: joeymt33
rocmar
rocmar
4,741
5,775
4 CORNERS
Very true
Reactions: joeymt33
