P700m4 skid plate choices
7,179
27,619
Looking for a little input on the different skid plates out there. tell me which one you have and what you like and dislike about it. I have done a little research on the two big hitters in the field(TrailArmor and SSS), but want some input. I may build my own but not sure if its worth my time to do that.
nbomar
nbomar
4,416
17,854
Springdale, AR
I'm running the factory utv uhmw. Ran them on my Polaris rzrs and had good luck so I bought it. It works great not hard to install. I did have to cut the front part of the wheel well guards because there was no way they were going to work. Tires would have rubbed like crazy.
Reactions: Tigermark
7,179
27,619
What brand is the one you have?
7,179
27,619
Sorry i see that is the brand
7,179
27,619
Dont see one for the 700-4 on there site
Ems-Cam
Ems-Cam
252
336
Alberta
I looked at all of them, my choice if I had bought was the SSS, but with shipping, exchange and such, I opted for b building my own out of 1/2" buckboard. It took a couple days but honestly I was messing around and didn't care about time. The material cost me about 300$ for 2 sheets of board and I have LOTS left to mess with. I want to make A-arm guards. The one picture shows some trimming left. The other to show I formed it over the bash plate on the front.
I would make it again in a heartbeat. Now that I understand cutting, which was just a sawzall, and measurements to overlap the sheets like the SSS brand, I could make another in a day.
Screen Shot 2017 02 04 at 104845 AM
Screen Shot 2017 02 04 at 104824 AM
7,179
27,619
I would make it again in a heartbeat. Now that I understand cutting, which was just a sawzall, and measurements to overlap the sheets like the SSS brand, I could make another in a day. View attachment 32256View attachment 32257
I like the looks of that, I can get the materials locally. I guess i just need to get a sheet and lay it out. Does anyone have a template for a 700-4, or want to remove theres and draw it out on a white bedsheet. Then they can send it to me.
Ems-Cam
Ems-Cam
252
336
Alberta
I have the cardboard I used for mine as a template. Using the old one only would leave you short.
What I did was stand my machine on end, then use cardboard from a large box and make the template. Its the same setup as the SSS. Another picture of the During with the cardboard on.
Then I bought some skid plate washers from a local ATV wrecker, bought 40 new grade 10.9 bolts and went to town. I used a router to overlap the sheets by 3/4", drilled a 7/8" hole after recessing the area.
Then on the outer rails, I used nut-serts, same thread as the main sheet which are m6x1.0. Given your location, I would recommend looking for a single sheet of the UHMW HDPE as they are sheets that are 5x10 where I needed 2 sheets of 4x8 to get what I needed.
Screen Shot 2017 02 04 at 33634 PM
Ems-Cam
Ems-Cam
252
336
Alberta
Also I Ended up trimming the area ahead of the rear wheels more than shown and the front where its curved, I cut off. Bending the front in the cold up here was a challenge.
7,179
27,619
Thanks for the ino. I think ill try your idea and make a pattern from a large box. How hard was it to bend? (Behind front tires)
Ems-Cam
Ems-Cam
252
336
Alberta
Because it was well below freezing, I didn't bend the area behind the tires. The front was not bad. I have a 220v space heater to warm it then concentrated heat with a heat gun, from there I used some clamps and a board to bend it. If I had decided to do this in July, it would have been much easier.
7,179
27,619
I think i will use a router to make a shollow grove on the top side and then try to bend.
What thickness did you use?
Ems-Cam
Ems-Cam
252
336
Alberta
1/2". Make sure you heat it though, it will work.
Reactions: Tramguage1
7,179
27,619
Thanks very much for the help.
Reactions: Ems-Cam
7,179
27,619
Does anyone know of any discounts through Trail Armor or SSS ?
Reactions: timholmesjr
Ems-Cam
Ems-Cam
252
336
Alberta
If your a first responder, SSS gives a 65$ discount and half shipping costs.
