SLOWPOKES PRE-FILTER SETUP
HUCK
HUCK
1,047
2,319
ARIZONA
Perfect photo, thanks. 👍
SLOWPOKE - if this is a highjack, I'll remove it - I posted here because of the pre-filter title.
And now the questions for HUCK. I'll start with 'I really like Bob's snorkel idea and have shared the photos of my copy 'over and over' because it's a great solution.
1. What's the part marked with a ? - that's not a Teryx tube, the bend is too sharp?
2. Since this is a constantly evolving idea - using one bend of the Teryx tube, I was able to come straight up through the body panel. If you did that, you wouldn't need the ? bend, you could use the lower rubber joint to lean the tube straight to the hole in the back window.
3. What back window is that? I want one and it would be great to know that it's 'cutable'.
4. I like that filter location. 👍
Straight up -
I'm sorry I can't tell you what the ? pipe is , it was just some of HondBobs stuff . As I said , we first ran it up and put the uni high {just under the roof) outside the back window . When I decided where it had to go , Bob and I just got-r-done . Easiest way was to turn the pipe and hook up from there . Bob has probably snorkeled 30 SXSs (20 have been his) so we discussed it and BAM there it is . The back window is SuperATVs dark tint . Shoot I have a video of HB cutting the back window but I can't find it .
Reactions: TxDoc and CID
CrosbyTalon
CrosbyTalon
59
117
Minnesota
I went with a little different setup. Wanted to keep it in cab without going through window and keep it as factory “looking” as possible. I may trim down the pipe in cab but left it long for now.
A21E99C3 6DC5 4C51 AA7B 0AAE9C1890E3 418C5710 9141 4172 A8F9 3F95A290E9CB 9D1987F9 5493 4F02 8F57 EE1179C0759D E544EA2B 33DA 4841 A294 A6A180F39692 7C4AFC1E 1A20 4BEC A036 4F3A1CECDC73 B0D2D8FA 37D2 4F31 9398 DF5D327DCE89
5,744
26,380
View attachment 231530 View attachment 231531 View attachment 231532 View attachment 231533 View attachment 231534 View attachment 231536
Since you removed the goofy air intake chamber and have the filter inside the cab, have you had any noise problems? 🤔 My single cylinder 650 dual sport was obnoxious with the air box cover removed (under the side number plate).
Reactions: TxDoc
CrosbyTalon
CrosbyTalon
59
117
Minnesota
There is a noteable change tgat I can hear but have not been able to test yet
Reactions: TxDoc
HUCK
HUCK
1,047
2,319
ARIZONA
Reactions: TxDoc
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Small test it has a bit of a deeper tone in the cab when really into the fun button but when cruising it is the same.
