P500 Smell antifreeze
JCart
JCart
895
2,021
Kamloops, BC Canada.
Hey Guys,
Been on the cool size here for some time now down to 0 F or -20 C and cooler, in the evenings. Anyways ploughing snow and have smelled antifreeze, had a look around yet none on the ground or dripping that I can see. Overflow seems ok, so I'm thinking it might be just a loose hose clamp under the seat area due to the cool weather. Runs fine, fan pops on once in a while, doesn't overheat just smells, but not all the time, just seems to as it get up to op temp. I did check the rad and it was full. Anyone else have these symptoms?
I'll pull the seat out and have a look tomorrow, hopefully I won't have to pull the skid plates.
j
Hey Guys,
j
I haven't had that or heard of it yet, good luck JC. Let us know.
allgm1
allgm1
1,049
1,484
New Hampshire
Same thing happened to me this year on my 700, I had a loose hose clamp on the heat exchanger, that had leaked a very small amount but enough so I caught a wiff of it. I tightened the one that was leaking, dried the area as best as I could and checked the rest of the clamps (there's a million of them on a 700 w/heater) just to be sure.
popeye
popeye
3,275
14,644
kapowsin, Wa
I was surprised and disappointed to see that honda used regular old school worm gear type of hose clamps. With the right tool a corbin style hose clamp are more reliable.
Easy now, you're bad mouthing the family. ;)
popeye
popeye
3,275
14,644
kapowsin, Wa
Just saying they are more reliable of a clamp. It makes sense for them to use them at the factory too. Because with the right tool they are faster
Oh I agree with you that they are better. Just have to be careful here. Wouldn't want to offend any sensibilities, lol.
hondabob
1,261
5,004
Prescott Valley, AZ
The top hose was loose at the cylinder head on mine. Made a mess on the engine but just tightened it and cleaned up the engine.
Able3605
Able3605
29
47
South Tx
Hey Guys,
j
JCart,I have a Ford F150 that had the same antifreeze smell with no obvious leaks.It turned out to be a pinhole in the heater core thus the smell was coming from the a/c / heater vents. A light, misty, oily fog of antifreeze was being blown throughout the cab. Different vehicles but same symptoms.
JCart
JCart
895
2,021
Thanks guys,
I just snugged up the top radiator hose clamp today and that seemed to take care of the odour. As suspected the hose connections need tightening due to cool weather. No sign of leaking fluid, but could readily twist hose at rad connection. I'll check under seat tomorrow, it's cool enough that I'm concerned of breaking push pins and plastics so I've not really dug into it. As there is still coolant in the overflow I've not been worried (overly), engine temp is right on point, two bars and fan clicks on periodically.
In terms of clamp style I like the old school worm gear clamps, (provided they are quality ones) the Corbin style are ok... I just like the option to tighten as clamping material ages.
jrc
allgm1
allgm1
1,049
1,484
New Hampshire
jrc
aren't the corbin style clamps a spring type clamp that would tighten itself? I would think the corbin style would be better, but its another one of those things I'll get to someday.
