P500 sneak peak of lift kit
283,395
I admire your enthusiasm for the P500 mods. When are you branching out from the youth models? :p
Eltobgi
Eltobgi
4,599
15,187
North Dakota
So let’s talk about mods necessary to support adding your producto_O
Will the factory Shocks work?
How about the axles?
Most importantly...What does the sticker for your product look like?:p
How much of a lift does this add over stock?
What’s the new width of the machine?
How is stability?
Will new brake lines be required?
And...How much for a complete set?
Thanks in advance:)
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
How is stability?
Thanks in advance:)
set up for stock shocks adds around 5" of lift needs 4x3 rims or wheel spacers to clear balljoint plates makes it 62" wide it comes full bolt on readt with balljoints longer tie rods axles( stock equivalent) and my stainless brakelines
