P1000 Snorkel list
A
angus56
40
40
North Texas
I just wadded up that pre filter and shoved in the PVC and secured it with a couple wires...Some are running filters my .02 is its not necessary your still flowing through the filter in the airbox . I do recommend the pre filter to keep out the large debris.
So with the foam pre filter stuck in the end of the hose is there an actual air filter past That? If so where is it.
sharp
sharp
3,757
14,955
Tennessee
Under a black plastic cover behind the front middle seat, several screws to get it off.
It's kind of a pain in the ass to get to.. I'm not real impressed with the design.
IMG 2434
Reactions: sharp
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Here's the other snorkel head and the quick release clamp I put on it.
what grommet did you use on the hood? custom or find one made for 3"
also when cutting the hole, did you measure up and over for center, or is there something on the bottom of the hood that shows center of intake.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Some one said they used a solo cup. Put it in the intake and had either a small flash light or laser pointer in the center of the cup. Put hood on and Mark and drill where the light hits
I use daily a piece of hose and split it..
I took the hood off and put the aluminum snorkel pipe on.. I then took a level and used it to make whiteness marks on the plastic outside of where the hood goes by placing it on each side of the pipe. That formed a square where the intake would come thru the hood. I put the hood back on and marked my square.. take the hood off and use a 3" hole saw to cut your hole.. remember that the pipe goes the the hood at and angle, so you want to cut it as such.
Does that make sense?
IMG 1747 IMG 1785 IMG 1787 IMG 2080
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I think i know what your talking about. thanks!
DMH
DMH
354
284
Central Florida
The noise isn't bad at all, it actually sounds pretty cool especially on take off.
Thanks, Wanting to avoid the " That's loud! I don't like that." from the wife as she stare's at it from the passenger seat. :D
Reactions: Nipper
