P1000 Snorkle air intake
john790
357
1,093
Clinton ohio 44216
For those of you that have added snorkles to your bike.I have a question did you do something to the ducting going to the engine the fittings mostly. I would like to seal mine better going under the bike. A bead of silcone or something like that.I dont plan on going swimming just for crossing a creek or a deep mud hole.I'll stand on the bank and watch you other guys.
JenElio
JenElio
73,152
665,944
Loxahatchee, florida
No holes just conections.
Check how good the connections are by blocking the breather port, engine should shut off with in a few seconds. If it doesn't then I would go around and find the "leak".
I don't see the need for silicone or the likes if it's all nice and tight like it should be. I play in water often and I've never had an issue with my snorkel.......🤞🤞🤞
Ridinfool
Ridinfool
36,144
386,046
Western North Carolina
I brought mine strait up through the hood, and not had any issues. Also what @JenElio said about checking that intake hose by removing hood and air box cover. Start buggy and cover the hole with your hand, if it dyes there are no leaks and you should be good. I have been in water that was up to my knees as I sat in the buggy with no problems.
824673FE 6982 40BD A543 C0023D84C9EA
Reactions: Lady01 and JenElio
