P1000 Snorkling the Pioneer 1000!
You going to snorkle your p1000
  • yes
    Votes: 59 78.7%
  • no
    Votes: 16 21.3%
  • Total voters
    75
Thanks for the info.
68,145
Looking at this more. I just noticed the water pump is NOT serviceable.
I hope its built well.
HL44E0500
MaleRN28US
MaleRN28US
271
125
Roanoke, Indiana
I just saw this. My thoughts would be that it may need a rebuild before you ever got to the point of the water pump wearing out. I would think 60k+ miles should be no problem for a Honda water pump.
Scooterchris
No longer active.
Dec 25, 2015
396
237
If you use these Bellows, you do not need to extend the line. The only line that you will need to extend higher is the fuel tank breather hose. Do not use these Bellows for the fuel tank.
I use the Bellows on both differentials and transfer case and the box under the drivers side that holds the adjustment for the parking brake.
As for the airbox, it is fully sealed. You may be able to build a snorkel coming out of the airbox. However, the space was pretty limited back there. It was just very easy for me to cut a hole in the hood up front and put a snorkel on. That way, I can return my vehicle back to stock very easily if I ever need to.
The radiator fan motor is also vented. I lengthened the vent hose for it further up under the hood to prevent debris from ruining my fan motor.
Reactions: Scooterchris
Scooterchris
No longer active.
Dec 25, 2015
396
237
Thank you. Is there a list somewhere of everything that needs to be vented farther up and where its located
If you don't see what you need in my build thread or @JACKAL build thread. Let me know and I will be glad to help.
As for the items that need to be snorkel, here are the ones that I know about:
Front diff
Rear diff
Sub trans
Fuel tank
Air intake
Parking brake adjustment box
Radiator fan motor
Bellows can be used on all of these things except for the air intake of course and the fuel tank. There is no problem extending the vent lines. I just chose to use the Bellows because it was easier and cleaner. However, they do cost more.
Scooterchris
No longer active.
Dec 25, 2015
396
237
Front diff
Rear diff
Sub trans
Fuel tank
Air intake
Radiator fan motor
Thank you. I will look his thread over and get with you if I need something else. Thanks buddy
Scooterchris
No longer active.
Dec 25, 2015
396
237
Front diff
Rear diff
Sub trans
Fuel tank
Air intake
Radiator fan motor
Sub trans/transmission the same thing?
The transmissions and engine share the same case.
The subtrans or transfer case is separate. It's under the passenger front seat.
Here's the pic of the vent for the subtrans.
E64fbc85495dea827e142f6fb49b3e21
Scooterchris
No longer active.
Dec 25, 2015
396
237
So the transmission/engine vent line is the air filter snorkel im gonna build?
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Any pictures of the bellows on the diffs?
I just unplugged the existing vent line from the frame and used a reducing barb to connect the bellows to the existing vent hose. Then ziptied the barb/clamp section to the frame to keep the bellows from bouncing around or being crushed by the bed. Jackals build thread and joeymt33's traveler II build thread both have additional pics with potential other ways to do the diff bellows.
20160215 140443
Scooterchris
No longer active.
Dec 25, 2015
396
237
Where is the cheapest place to find bellows? And can they get them to me before saturday?
