We got 16 inches of fresh snow.
This machine is amazing in the snow - what a blast!
I think I figured out posting videos....
Yeah I got a couple spins in. There's not a lot of room for that - pretty tight trails and some nasty drop-offs.On compact snow and ice in 4wd with an open front diff and they'll spin like a top
Yeah I was impressed. And you plow thru that stuff faster than I expected.Wow! That looks like so much fun to a Bama boy.
It seems amazing that it can keep pushing in the deep snow.
One thing to keep in mind when working a mechanical injection system is think of it like your brakes. If there is air in the fuel sytem the injection pump struggles to achieve the high fuel pressure thats needed to make the popit valves open up. It might help to crack the lines loose at the injectors to bleed the air out.Yeah I got a couple spins in. There's not a lot of room for that - pretty tight trails and some nasty drop-offs.
We just got another 6 inchs of snow and my tractor broke down blocking the driveway. I dont know alot about diesels but I know the fuel isnt flowing.
We just got our satellite internet back after the white-out so I have a few more things to try after searching for "Air in fuel filter".
Yeah - thanks. I think you're right. The fuel filter was a bit loose so I think some air might have seeped in.One thing to keep in mind when working a mechanical injection system is think of it like your brakes. If there is air in the fuel sytem the injection pump struggles to achieve the high fuel pressure thats needed to make the popit valves open up. It might help to crack the lines loose at the injectors to bleed the air out.
The issue with your diesel tractor may be the cold, diesel fuel will start to turn to a gel, it won't pump, gets to thick, when temp gets below 15-20 degree f. if the fuel isn't teated with a anti gel additive. You said you didn’t know much about diesels. Just a thought. If that's the case try t o get it inside to warm up, then start it, the add fuel additive.Yeah I got a couple spins in. There's not a lot of room for that - pretty tight trails and some nasty drop-offs.
