Does Anyone know about wear on sand and gravel? That is 90% of my riding.
Running Tusk Terrabite® Radial Tire's - Medium/Hard Terrain.
Any insight?
Any insight?
Governor kicks in at 43MPH anywayBecause my 700 is screaming at 40mph.
I have a hillbilly brake on my 1000 works great when I have it parked in my driveway and use it when I go shoppingYes. 1000 has turf but NO park brake.
If I'm reading the law right, you don't even need a windshield with a full helmet.
Just turn singal, horn, and park brake.
Sorry 500 guys, you don't meet size requirements currently.
Depends on the tire and if you are going in circles, you will scrub off tires fast but scrub only happens when you are turning and road driving is mostly straight. I drive my Talon on paved roads quite a bit and after 1500 miles, my Terrabites are barely worn.The pioneer700 has locked rear end. Am I going to eat through a pair a tires every 100 miles riding on paved roads?. Thinking about trading up to a 1000, I can’t find if they have a turf mode.
Terrabites last forever. I have 1,500 miles mixed trail, rock sand and pavement and they are barely worn.Does Anyone know about wear on sand and gravel? That is 90% of my riding.
Any insight?
I would agree with this. Unless the law is specific (like a few states) and say "A separate hand operated park brake system independent of the hydraulic foot brakes", then anything that will hold the brakes while parked should suffice.Yeah you can add a Hillbilly brake or something NC folks, pretty sure that would get you there if they really need to see one.
Tennessee didn't even inspect my vehicle, they just took the $24 and handed me a plate.
Any good radial tire that isn't a super aggressive mud tire like the ITP XTR will work fantastic in those like your tusks. The ITP terracross is an incredible tire as well and will get just as good if not better wearDepends on the tire and if you are going in circles, you will scrub off tires fast but scrub only happens when you are turning and road driving is mostly straight. I drive my Talon on paved roads quite a bit and after 1500 miles, my Terrabites are barely worn.
@hondabob got 15,000+ miles with a set on his Talon that he mostly used in Arizona desert terrain.
This is most interesting! Does this apply to D.O.T. approved tires like the Terrabite? If so, I will need to keep an eye on mine.As a tire distributor I can tell you that running around at highway speed on asphalt with deep lug tires will almost certainly cause cracking at the base of your tire lugs. Heat and the inability of the tires to loose traction on asphalt causes this.
The 1000 has turf modeThe pioneer700 has locked rear end. Am I going to eat through a pair a tires every 100 miles riding on paved roads?. Thinking about trading up to a 1000, I can’t find if they have a turf mode.
My 700 has never been on pavement, just clay and gravel. 4100 miles and I just installed my third set of tires. Went to 8 ply Trilobites.My P1000-3 has only been driven on blacktop pavement. The odometer is showing about 950 miles and the tires show very little wear. If the tires are worn out by 6000 - 8000 miles that will give me an excuse to buy a set of light truck winter tires. Any tires that don't howl so loud I have to wear ear protectors will be good.
Who needs a parking brake? The P1000s have a PARK position in the transmission which locks the driveline.
My P1000 is insured, inspected, and licensed in WV iaw with the stature. I had to add inside and outside rear view miorrors, turn signals, and a horn to pass inspection.
I suspect some state legislators were badly advised when drafting their ORV laws.
You've driven an automatic car presumably. P for park right. And then there is also a parking brake (electronic button "somewhere", far left foot well pedal, or center console hand operated). The P1k only has the P for park....which doesn't set a brake at all.Question: How is the brake on the Pioneer 1000's not a parking brake. I shift the shift lever into P, which stands for Park. How is that not a parking brake?
Thanks for the explanation. Hard to understand how there could be a restriction that says the machine needs a "parking brake".You've driven an automatic car presumably. P for park right. And then there is also a parking brake (electronic button "somewhere", far left foot well pedal, or center console hand operated). The P1k only has the P for park....which doesn't set a brake at all.
I was able to get a after market parking break from my Honda Dealer, they installed it. Was $75 dollars with a $25 dollar installation fee.Man that sucks, I was thinking about getting a 1000. I can’t believe it doesn’t have a parking break. But they do have turf mode?
Most likley a @Hillbilly Brake.I was able to get a after market parking break from my Honda Dealer, they installed it. Was $75 dollars with a $25 dollar installation fee.
It goes on the floor on the drivers side and you push it in and lock it, and push again to unlock...its installed with two bolts and pinches the brake cable when you push it in the locked position. Unlocked the cable slides free.
Handbrakes (auxiliary, parking or holding) shall not be approved if: (a) There is no lever reserve when the brake is fully applied. (b) Cables are visibly frayed or frozen, or there are missing or defective cotter pins or broken or missing retracting springs or worn rods or couplings. (c) The operating mechanism, when fully applied, fails to hold the brakes in the applied position without manual effort. (d) When emergency or handbrakes are applied they fail to hold vehicle.
