I just recently put front and rear A arm skid plates on the 1000-5.
Soon after this I noticed my brakes Not working correctly. After running it around in the yard not hard at all I went to a neighbors as I approach the driveway I tried to slow down and the pedal went to the floor.
however I pump the brakes three times and regain The brakes
Took it home into the garage to look at the brakes. There was some brake fluid leaking off of the brake hose going to the cylinder.
Then I looked at the clearance as I move the steering wheel from right to left nothing seem to be pinching the hose or rubbing the brakehub.
Anyone else have this issue or something similar?
The hose fitting that was leaking was not enough for me to think that would cause the pedal to go to the floor
